I’m running on a docker container and haven’t made much changes from the default configuration noted in the installation. I have the redirect URI in Google set as Link to OAuth2 Authorize Callback – My Home Assistant and it opens My Home Assistant after the authentication via Google. I’m not sure what instance URL I should be using and tried several and got the corresponding errors after clicking Link Account
I don’t think I have network problems. I primarily access my instance on my mini PC (linux) via localhost. I am also able to access my instance on other devices on my network via the static IP address. I don’t have a DNS or VLAN set up. For the setup, I am running it through a container via Docker Compose with this config:
The only changes I tried to make for the HA config is for logging.
# Loads default set of integrations. Do not remove.
default_config:
logger:
logs:
homeassistant.components.google: debug
homeassistant.helpers.config_entry_oauth2_flow: debug
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
I was able to setup other integrations - MQTT, Frigate (via HACS), and Alexa. I believe that’s all I’ve done in terms of setup so far. Let me know if there’s something specific!
