last night, the interface has shown a new update to the HA Yellow zigbee/thread module (from 7.4.4.1 to 7.4.4.2). I let it install and went to sleep. After a few hours, it was still at 49 % updating, and didn’t move at all. All ZigBee connections (using ZHA) were down.
I restarted HA core (maybe not the best idea at this point) and cannot get the ZigBee module to work again.
The following two entries in the log seem to be related to this:
Logger: homeassistant.config_entries
Quelle: config_entries.py:751
Erstmals aufgetreten: 07:17:44 (1 Vorkommnis)
Zuletzt protokolliert: 07:17:44
Error setting up entry Home Assistant Yellow for zha
File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 109, in reset
return await self._reset_future
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 140, in connect
await self.startup_reset()
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 129, in startup_reset
await self.reset()
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 148, in reset
await self._gw.reset()
File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 108, in reset
async with asyncio_timeout(RESET_TIMEOUT):
File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
raise TimeoutError from exc_val
TimeoutError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 751, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 156, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 273, in async_initialize
await self._async_initialize()
File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 256, in _async_initialize
await self.application_controller.startup(auto_form=True)
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 238, in startup
await self.connect()
File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 155, in connect
await self._ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 142, in connect
await self.disconnect()
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 207, in disconnect
await self._gw.disconnect()
asyncio.exceptions.CancelledError: Global task timeout: Bootstrap stage 2 timeout
Logger: homeassistant.bootstrap
Quelle: bootstrap.py:931
Setup timed out for stage 2 waiting on set() - moving forward
When I try to reconfigure the serial interface in ZHA, it says “connection failed”, and then that the serial connection is locked by another application.
I tried restarting the entire system, and even unplugged its power connection, but that didn’t change anything.
Any ideas?
