reset the network key and repaired, still no luck. Node 22 is the garage opener:
[20210222 14:17:19.469 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x20, 0x01, 0x80, 0x7e, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x28
[20210222 14:17:19.470 EST] [ozw.library] [info]: Info - Node: 22 Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
[20210222 14:17:19.470 EST] [ozw.library] [info]: Info - Node: 22 Neighbors of this node are:
[20210222 14:17:19.470 EST] [ozw.library] [info]: Info - Node: 22 Node 2
[20210222 14:17:19.471 EST] [ozw.library] [info]: Info - Node: 22 Node 3
[20210222 14:17:19.471 EST] [ozw.library] [info]: Info - Node: 22 Node 4
[20210222 14:17:19.471 EST] [ozw.library] [info]: Info - Node: 22 Node 5
[20210222 14:17:19.471 EST] [ozw.library] [info]: Info - Node: 22 Node 6
[20210222 14:17:19.472 EST] [ozw.library] [info]: Info - Node: 22 Node 7
[20210222 14:17:19.472 EST] [ozw.library] [info]: Info - Node: 22 Node 20
[20210222 14:17:19.472 EST] [ozw.library] [debug]: Detail - Node: 22 Expected reply was received
[20210222 14:17:19.472 EST] [ozw.library] [debug]: Detail - Node: 22 Message transaction complete
[20210222 14:17:19.473 EST] [ozw.library] [debug]: Detail - Node: 22 Removing current message
[20210222 14:17:19.473 EST] [ozw.library] [debug]: Detail - Node: 22 Query Stage Complete (Neighbors)
[20210222 14:17:19.473 EST] [ozw.library] [debug]: Detail - Node: 22 AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
[20210222 14:17:19.473 EST] [ozw.library] [debug]: Detail - Node: 22 QueryStage_Session
[20210222 14:17:19.473 EST] [ozw.library] [debug]: Detail - Node: 22 Queuing (Query) PowerlevelCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x73, 0x02, 0x25, 0x4c, 0xe9
[20210222 14:17:19.474 EST] [ozw.library] [debug]: Detail - Node: 22 Queuing (Query) Query Stage Complete (Session)
[20210222 14:17:19.474 EST] [ozw.library] [info]: Info - Node: 22 Sending (Query) message (Callback ID=0x4c, Expected Reply=0x04) - PowerlevelCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x73, 0x02, 0x25, 0x4c, 0xe9
[20210222 14:17:19.474 EST] [ozw.library] [info]: Info - Node: 22 Encrypted Flag is 0
[20210222 14:17:19.480 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20210222 14:17:19.480 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA delivered to Z-Wave stack
[20210222 14:17:19.494 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x05, 0x00, 0x13, 0x4c, 0x00, 0xa5
[20210222 14:17:19.495 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA Request with callback ID 0x4c received (expected 0x4c)
[20210222 14:17:19.495 EST] [ozw.library] [info]: Info - Node: 22 Request RTT 21 Average Request RTT 20
[20210222 14:17:19.495 EST] [ozw.library] [debug]: Detail - Node: 22 Expected callbackId was received
[20210222 14:17:19.505 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x16, 0x04, 0x73, 0x03, 0x00, 0x00, 0x93
[20210222 14:17:19.505 EST] [ozw.library] [info]: Info - Node: 22 Response RTT 31 Average Response RTT 31
[20210222 14:17:19.506 EST] [ozw.library] [info]: Info - Node: 22 Received a PowerLevel report: PowerLevel=Normal, Timeout=0
[20210222 14:17:19.506 EST] [ozw.library] [debug]: Detail - Node: 22 Initial read of value
[20210222 14:17:19.507 EST] [ozw.library] [debug]: Detail - Node: 22 Initial read of value
[20210222 14:17:19.507 EST] [ozw.library] [debug]: Detail - Node: 22 Expected reply and command class was received
[20210222 14:17:19.507 EST] [ozw.library] [debug]: Detail - Node: 22 Message transaction complete
[20210222 14:17:19.508 EST] [ozw.library] [debug]: Detail - Node: 22 Removing current message
[20210222 14:17:19.508 EST] [ozw.library] [debug]: Detail - Node: 22 Notification: ValueChanged CC: COMMAND_CLASS_POWERLEVEL Instance: 1 Index: 0
[20210222 14:17:19.509 EST] [ozw.library] [debug]: Detail - Node: 22 Notification: ValueChanged CC: COMMAND_CLASS_POWERLEVEL Instance: 1 Index: 1
[20210222 14:17:19.509 EST] [ozw.notifications] [debug]: Notification pvt_valueChanged: 383565844 Thread: 0x7fa061de38
[20210222 14:17:19.510 EST] [ozw.library] [debug]: Detail - Node: 22 Query Stage Complete (Session)
[20210222 14:17:19.510 EST] [ozw.library] [debug]: Detail - Node: 22 AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
[20210222 14:17:19.510 EST] [ozw.library] [debug]: Detail - Node: 22 QueryStage_Dynamic
[20210222 14:17:19.511 EST] [ozw.library] [debug]: Detail - Node: 22 Queuing (Send) BasicCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x20, 0x02, 0x25, 0x4d, 0xbb
[20210222 14:17:19.511 EST] [ozw.library] [debug]: Detail - Node: 22 Queuing (Send) SensorBinaryCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x30, 0x02, 0x25, 0x4e, 0xa8
[20210222 14:17:19.511 EST] [ozw.mqtt.publisher.value] [debug]: List Selected Value has Not Changed: "Normal"
[20210222 14:17:19.511 EST] [ozw.library] [debug]: Detail - Node: 22 Queuing (Query) Query Stage Complete (Dynamic)
[20210222 14:17:19.512 EST] [ozw.library] [info]: Info - Node: 22 Sending (Send) message (Callback ID=0x4d, Expected Reply=0x04) - BasicCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x20, 0x02, 0x25, 0x4d, 0xbb
[20210222 14:17:19.512 EST] [ozw.library] [info]: Info - Node: 22 Encrypted Flag is 0
[20210222 14:17:19.514 EST] [ozw.mqtt.publisher] [debug]: Publishing Event valueChanged: 383565844
[20210222 14:17:19.514 EST] [ozw.notifications] [debug]: Notification pvt_valueChanged: 281475360276497 Thread: 0x7fa061de38
[20210222 14:17:19.516 EST] [ozw.mqtt.publisher] [debug]: Publishing Event valueChanged: 281475360276497
[20210222 14:17:19.521 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20210222 14:17:19.521 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA delivered to Z-Wave stack
[20210222 14:17:19.533 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x05, 0x00, 0x13, 0x4d, 0x00, 0xa4
[20210222 14:17:19.533 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA Request with callback ID 0x4d received (expected 0x4d)
[20210222 14:17:19.533 EST] [ozw.library] [info]: Info - Node: 22 Request RTT 20 Average Request RTT 20
[20210222 14:17:19.533 EST] [ozw.library] [debug]: Detail - Node: 22 Expected callbackId was received
[20210222 14:17:29.514 EST] [ozw.library] [critical]: Error - Node: 22 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "BasicCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x20, 0x02, 0x25, 0x4d, 0xbb"
[20210222 14:17:29.514 EST] [ozw.library] [debug]: Detail - Node: 22 Removing current message
[20210222 14:17:29.514 EST] [ozw.library] [debug]: Detail - Node: 22 Notification: Notification - TimeOut
[20210222 14:17:29.515 EST] [ozw.library] [info]: Info - Node: 22 Sending (Send) message (Callback ID=0x4e, Expected Reply=0x04) - SensorBinaryCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x30, 0x02, 0x25, 0x4e, 0xa8
[20210222 14:17:29.515 EST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_MsgTimeout Thread: 0x7fa061de38
[20210222 14:17:29.517 EST] [ozw.library] [info]: Info - Node: 22 Encrypted Flag is 0
[20210222 14:17:29.517 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwNotification
[20210222 14:17:29.523 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20210222 14:17:29.524 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA delivered to Z-Wave stack
[20210222 14:17:29.538 EST] [ozw.library] [debug]: Detail - Node: 22 Received: 0x01, 0x05, 0x00, 0x13, 0x4e, 0x00, 0xa7
[20210222 14:17:29.538 EST] [ozw.library] [debug]: Detail - Node: 22 ZW_SEND_DATA Request with callback ID 0x4e received (expected 0x4e)
[20210222 14:17:29.538 EST] [ozw.library] [info]: Info - Node: 22 Request RTT 21 Average Request RTT 20
[20210222 14:17:29.539 EST] [ozw.library] [debug]: Detail - Node: 22 Expected callbackId was received
[20210222 14:17:32.685 EST] [ozw.mqtt.publisher] [debug]: "Mon Feb 22 14:17:32 2021 PingResponse\n"
[20210222 14:17:39.518 EST] [ozw.library] [critical]: Error - Node: 22 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "SensorBinaryCmd_Get (Node=22): 0x01, 0x09, 0x00, 0x13, 0x16, 0x02, 0x30, 0x02, 0x25, 0x4e, 0xa8"
[20210222 14:17:39.518 EST] [ozw.library] [debug]: Detail - Node: 22 Removing current message
[20210222 14:17:39.519 EST] [ozw.library] [debug]: Detail - Node: 22 Notification: Notification - TimeOut
[20210222 14:17:39.519 EST] [ozw.library] [debug]: Detail - Node: 22 Query Stage Complete (Dynamic)
[20210222 14:17:39.519 EST] [ozw.library] [debug]: Detail - Node: 22 AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
[20210222 14:17:39.520 EST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_MsgTimeout Thread: 0x7fa061de38
[20210222 14:17:39.520 EST] [ozw.library] [debug]: Detail - Node: 22 QueryStage_Configuration
[20210222 14:17:39.520 EST] [ozw.library] [debug]: Detail - Node: 22 QueryStage_Complete
[20210222 14:17:39.520 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwNotification
[20210222 14:17:39.521 EST] [ozw.library] [warning]: Warning - Node: 0 CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
[20210222 14:17:39.521 EST] [ozw.library] [info]: Info - Node: 0 Saving Cache
[20210222 14:17:39.523 EST] [ozw.library] [info]: Info - Node: 1 Cache Save for Node 1 as its QueryStage_CacheLoad
[20210222 14:17:39.526 EST] [ozw.library] [info]: Info - Node: 2 Cache Save for Node 2 as its QueryStage_CacheLoad
[20210222 14:17:39.529 EST] [ozw.library] [info]: Info - Node: 3 Cache Save for Node 3 as its QueryStage_CacheLoad
[20210222 14:17:39.532 EST] [ozw.library] [info]: Info - Node: 4 Cache Save for Node 4 as its QueryStage_CacheLoad
[20210222 14:17:39.534 EST] [ozw.library] [info]: Info - Node: 5 Cache Save for Node 5 as its QueryStage_CacheLoad
[20210222 14:17:39.535 EST] [ozw.library] [info]: Info - Node: 6 Cache Save for Node 6 as its QueryStage_CacheLoad
[20210222 14:17:39.536 EST] [ozw.library] [info]: Info - Node: 7 Cache Save for Node 7 as its QueryStage_CacheLoad
[20210222 14:17:39.537 EST] [ozw.library] [info]: Info - Node: 20 Cache Save for Node 20 as its QueryStage_CacheLoad
[20210222 14:17:39.538 EST] [ozw.library] [info]: Info - Node: 21 Cache Save for Node 21 as its QueryStage_CacheLoad
[20210222 14:17:39.539 EST] [ozw.library] [info]: Info - Node: 22 Cache Save for Node 22 as its QueryStage_CacheLoad
[20210222 14:17:39.565 EST] [ozw.library] [debug]: Detail - Node: 22 Notification: NodeQueriesComplete
[20210222 14:17:39.565 EST] [ozw.notifications] [debug]: Notification pvt_nodeQueriesComplete 22 Thread: 0x7fa061de38
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodeDeviceType : QVariant(int, 3078) Transaction: true
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodeDeviceTypeString : QVariant(QString, "Access Control Sensor") Transaction: true
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodeRole : QVariant(int, 5) Transaction: true
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodeRoleString : QVariant(QString, "Always On Slave") Transaction: true
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodePlusType : QVariant(int, 0) Transaction: true
[20210222 14:17:39.566 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodePlusTypeString : QVariant(QString, "Z-Wave+ node") Transaction: true
[20210222 14:17:39.567 EST] [ozw.nodes] [debug]: setNodeData 22 : QTOZW_Nodes::NodeQueryStage : QVariant(QString, "Complete") Transaction: true
[20210222 14:17:39.569 EST] [ozw.mqtt.publisher] [debug]: Publishing Event nodeQueriesComplete: 22
