Issues with notifications during network failover
Hello everyone,
I’ve been working for a couple of days on configuring a failover setup on a MikroTik router to maintain internet connectivity via LTE when the fiber connection goes down.
Main issue
The failover itself works correctly, but I have a major problem:
I am NOT receiving notifications on my mobile device when switching between Fiber and 4G (failover), especially when the phone is connected via WiFi.
Observed behavior:
  • If the phone is on WiFi:
    • Notifications stop arriving after the failover.
    • They only resume if I manually change the connection (e.g., switching to mobile data).
  • If the phone is on mobile data (4G/5G):
    • Everything works correctly, no issues.
  • Additionally:
    • Home Assistant Cloud takes some time to reconnect (I partially mitigated this by restarting it via webhook).
This leads me to believe the issue is related to persistent connections/sockets that become invalid after the public IP changes.
Context
Initially, I also had issues with Home Assistant Cloud after failover, but I solved that by sending a webhook to Home Assistant to force a cloud reconnection.
However, the notification issue still persists, which is my main concern right now.
Current network topology
  • ISP router (fiber)
  • MikroTik (handling 4G failover)
  • TP-Link Deco Mesh (in router mode)
I know this is not ideal. My future plan is:
  • ONT + MikroTik as the main router
  • Deco in AP mode
But for now, I prefer not to change this until everything is stable.
Failover behavior
  • WAN (fiber) → distance 1
  • LTE (4G) → distance 2
The failover works correctly:
  • Automatic
  • Fast
  • No noticeable interruptions
The issue is not the failover itself, but what happens afterward.
Technical issue observed
When switching between Fiber and 4G:
  • The public IP changes
  • Some connections remain open or become invalid
This results in:
  • Notifications not being received over WiFi
  • Temporary issues with Home Assistant Cloud
  • Affects both cloud access and local access (I use Tailscale)
MikroTik script
I use the following script to detect the change and trigger actions:
:global lastState
:local haIP "IP_HOME_ASSISTANT"
:local activeRoutes [/ip route find where dst-address="0.0.0.0/0" active=yes]
:local bestDist 999
:foreach i in=$activeRoutes do={
    :local d [/ip route get $i distance]
    :if ($d < $bestDist) do={
        :set bestDist $d
:log info "[CHECK] Active distance: $bestDist | Previous state: $lastState"
:if ($bestDist = 1) do={
    :if ($lastState != "WAN") do={
        :log warning "[FAILOVER] >>> SWITCH to FIBER (distance=$bestDist)"
        /tool fetch url="http://$haIP:8123/api/webhook/failover_fiber" http-method=post keep-result=no
        :set lastState "WAN"
        :delay 5s
        /ip firewall connection remove [find protocol=tcp dst-address=$haIP dst-port=8123]
        /ip firewall connection remove [find protocol=tcp src-address=$haIP src-port=8123]
        /ip firewall connection remove [find dst-address-type=!local]
        /ip dns cache flush
} else={
    :if ($lastState != "4G") do={
        :log warning "[FAILOVER] >>> SWITCH to 4G (distance=$bestDist)"
        /tool fetch url="http://$haIP:8123/api/webhook/failover_4g" http-method=post keep-result=no
        :set lastState "4G"
        :delay 5s
        /ip dns cache flush
Home Assistant automation
When the webhook is received:
  • It restarts Home Assistant Cloud
  • Sends a critical notification to the mobile device
Questions
I would like to understand:
  • Am I handling connection tracking correctly?
  • Is removing connections this way the right approach?
  • Is there a better way to prevent persistent connections from breaking after an IP change?
  • How is this typically handled in failover setups with services like Home Assistant?
Any help or guidance would be greatly appreciated.
Right now, failover works perfectly, but notifications are no longer reliable, which is exactly what I need to fix.
Thank you in advance! :raised_hands:
What happens if you just reboot the router to force all your devices to form a new connection?
From the looks of it, you’re only having an issue when you’re at home and connected to WiFi? I don’t use the Home Assistant cloud, I just connect locally and have a vpn that all my devices connect to when I’m not at home but on my network (also running with a Mikrotik router) I have all my home services have their Domain Name route directly to the local address so my public IP is irrelevant. Everything does have a FQDN but they all route directly to their private IP on the home network. I have a PiHole running but you can have custom DNS entries on Mikrotik too.
Maybe this might solve your problem?
Alternatively, you can also drop a wifi connection from the WiFi section of the GUI. Knowing Mikrotik, you’ll be able to do the same thing through the terminal to drop your phone and force it to reconnect (as long as your phone isn’t using a randomised MAC).
These reconnections happen in seconds, I do that when I’m assigning a new static IP to a device.
The nuclear option would be to reboot the router and just force everything to make a new connection.
Persistent sessions over changing IP Addresses is probably asking a little too much from HomeAssistant, especially if the notifications are in real time and not queued.
Telegram should work fine in those scenarios.
I would prefer not to switch to Telegram or similar, because it would mean losing actions that I have configured exclusively for notifications (such as a button to disable the effects when the alarm is triggered without disabling it).
I do not understand why you are not trying to do this with ‘your future plan’? As it stands you are using at least Double-NAT which means the Deco is managing state for connections via the MESH and the MikroTik is the managing state for all outbound connections. By putting the Deco into AP mode you will be pass all the wifi state management onto the MikroTik.
Hi, I’ll explain the situation, as there have been quite a few changes during this time.
I wanted to send an update once everything was fully fixed, but I’m afraid I’ve reached a dead end.
The first change is that I’ve set the Mesh router to Access Point mode. Right now, Mikrotik is handling all network connections.
The second change is that I managed to fix the issue where Home Assistant Cloud would go down or become unavailable for more than a few seconds (restarting from Home Assistant didn’t work).
My solution is somewhat complex and has a cost, but fortunately I found a good deal and decided to give it a try.
To prevent Home Assistant Cloud from going down, I’m routing all my traffic through WireGuard to a VPS server. This way, from Home Assistant’s perspective, my public IP doesn’t change, which prevents outages or keeps downtime to a minimum (sometimes just around 2 seconds).
However, regarding notifications… nothing works. Neither deleting the connections (which are now managed by Mikrotik, and I also tested by connecting directly to Mikrotik’s Wi-Fi), nor trying alternatives like Pushover… nothing.
So at this point, it seems the issue is on the client side (i.e., the mobile device). I’ll probably need to use something like Tasker, although I still haven’t figured out the best way to approach this. I’ll keep looking into it in the future.
For the notifications, do they start again sometime after the connections switch?
You could try using the Deco API to reboot the mesh to force all WiFi clients to establish new connections.
Well, after analyzing it carefully in my spare time, I finally got to the root of the problem.
I was looking in the wrong place. The issue wasn’t with Home Assistant or the notification delivery, which works correctly, but with the mobile device itself: it keeps connections open with an IP that becomes unreachable when switching networks, which causes the loss of connectivity.
The ideal solution would be as simple (though not in my case to implement) as forcing a temporary WiFi disconnection on the phones: blocking their access for a few seconds and then restoring it, forcing them to properly renew their connection.
The problem is that my TP-Link Deco BE3600 has several limitations:
  • It does not have an official API.
  • TP-Link Deco integrations are read-only.
  • TP-Link Router integrations are restricted on this model (for example, they do not allow enabling or disabling WiFi).
As an alternative, I solved it using Python by rebooting the Deco. Initially, I tried programming it myself, but it was slower than the final solution I implemented using the tplinkrouterc6u library.
To avoid losing access to essential devices during reboots, I took advantage of the fact that the Deco was already in access point mode and reorganized the network: I connected critical devices (Home Assistant, cameras, and Hue sensors) directly to the MikroTik router. This way, these devices are not affected when the rest of the network is restarted.
Finally, I’ll also leave here the solution to the Home Assistant Cloud disconnection issues: I fixed it by using WireGuard on a VPS, ensuring a stable public IP. I had previously tried restarting the Home Assistant Cloud service, but that didn’t work.
In summary, these are not particularly simple or elegant solutions, nor the cheapest ones, but given the limitations of my current setup, they have been the most effective in achieving stability.
Well, in the end I managed to solve the problem properly, just as I mentioned.
I currently have a fairly advanced network setup that does exactly what I wanted. First, I switched my TP-Link Deco mesh Wi-Fi system to access point mode. In addition, I recently configured my ISP router in ONT mode, so the MikroTik now fully manages my main network, while the TP-Link Deco system is responsible only for Wi-Fi coverage.
Additionally, I set up a second mesh network dedicated to essential devices, where the cameras are connected, while other critical devices, such as the Hue sensors and the camera hub, are connected directly to the MikroTik router. This way, even if I need to reboot the TP-Link Deco system on the main network, all essential infrastructure remains operational and never restarts.
On top of that, I use WireGuard to route Home Assistant through an external VPS, which prevents it from becoming inaccessible in the event of local connectivity issues or network changes. Thanks to this architecture, Home Assistant remains accessible at all times, and together with the cameras and sensors, the critical system stays continuously operational.
All of this, combined with the UPS units I have protecting essential devices and a few “canary” sensors to detect potential signal jamming attempts, makes for a pretty interesting setup, haha.
