Issues with web browser on windows computers
Since few days, web access to Home Assistant has some issues. I tested with different web browsers (Chrome, Brave & Edge) and different windows computers and got the same behaviour.
For example, If I click on a sensor value, click on parameter icon (top right of window) and then click on the bottom right Update button, the browser move back to an empty page.
No issue on my Android or IOS devices. No issue when using Firefox which is not chromium based.
I haven’t find anything about that kind of issue.
Any ideas?
Thanks in advance
Same issue here, you are not alone! Addressing Navigation Issues in Chrome | Loom
I find something that works so far on https://www.reddit.com/r/homeassistant/comments/1ojtss0/weird_browser_back_behavior_when_interacting_with/
I disabled NordPass extension and the issue was gone.
If I enable it, the issue is back.
Is installed a non chromium web browser, Firefox. No problem even with the NordPass extension activated.
I just log a fix request to NordPass support.
Hope this help
Impressive research! I use NordPass as well, will check it out!
