On my Home Assistant (HA), I’m using the Z-Wave JS add-on, which is now causing problems for the second time in a row. As soon as a new update becomes available, HA already starts displaying error messages. Most recently, this issue started at the end of last week when the update to version 0.18.0 became available. Even installing the update did not resolve the problem, meaning I can no longer control my devices. Sometimes a reboot helps for a few hours, sometimes unplugging and replugging the Z-Wave stick does, otherwise only restoring a backup works. Finally I spent two weeks now get it back running stable and it drives me mad.
With the previous update a few months ago, I had to restore the backup three times, then it worked again — until last weekend.
Error message:
“The action cover/close_cover could not be executed.
Unable to set value 50-38-0 targetValue: zwave_error: Z-Wave error 202 - Failed to send the command after 1 attempts (ZW0202).”
Stick: zooZ 800 Z-Wave Stick ZST39
Trying different USB ports didn’t help either.
Core: 2025.7.2
Supervisor: 2025.07.01
Operating System: 16.0
Frontend: 20250702.2
Even though the devices can’t be controlled via HA, their states — such as on/off for lights — are still being reported to HA.
Z-Wave driver version: 15.6.0
Server version: 3.1.0
As mentioned before, the issues already occur when a Z-Wave update is merely available — even before it’s installed.
Thursday I updated the Z-Wave stick to version 1.60 via the JS UI (I tried to use it instead, as there are more options for failure analysis) and initiated a re-routing and node refresh overnight. However, the day after there was still no improvement. So, I reverted to the backup from three days ago and also back to Zwave JS. For a couple of hours my devices were available again. If not, it was possible to get them back to work with pinging.
In between HA is also updated to the latest version.
- Installationsmethode Home Assistant OS
- Core 2025.7.3
- Supervisor 2025.07.1
- Operating System 16.0
- Frontend 20250702.3
Any idea to get rid of this issue? Same or similar experiences?
