I just updated to the new ISY994i integration, where it is now using the number.set_value service vs. the isy994.set_variable service. After upgrading, HA asked to repair the ISY994i integration, which I did. After a RESTART, I was looking at my Overview Dashboard and see new entities under “HOME”. When I went to increment an entity ( HA.Integer_String1 ), that I believe will set the variable to this value on my ISY994i, I get an error.
“Failed to call service number/set_value. Could not set HA.Integer_String1 to 12459.0 for 1.67”
Here are the two log entries for the error.
Logger: pyisy
Source: components/isy994/number.py:236
First occurred: 4:23:23 PM (2 occurrences)
Last logged: 4:23:23 PM
ISY Reported an Invalid Command Received /vars/set/1/67/12462.0
ISY could not set variable: 1.67
Second error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/isy994/number.py:237
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 4:23:23 PM (1 occurrences)
[548043736592] Could not set HA.Integer_String1 to 12462.0 for 1.67
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1787, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1824, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 968, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 720, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/number/__init__.py", line 96, in async_set_value
await entity.async_set_native_value(native_value)
File "/usr/src/homeassistant/homeassistant/components/isy994/number.py", line 237, in async_set_native_value
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Could not set HA.Integer_String1 to 12462.0 for 1.67
My system is up to date:
Home Assistant 2023.2.2
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
Any insight to this error is appreciated, thank you!
