@Ash.xiao as suspected, Sonoff marketing about adapters supporting Multi-Protocol / Multi-PAN is now confusing several users who think that using is a good idea to use that in their setup even though developers of Home Assistant’s ZHA integration and Zigbee2MQTT made it clear that it is not recommended.
@Ash.xiao Again, suggest you change all your marketing to clearify this as saying something is supported leads to a bad experience for both users and developers because people think that something should be supported if you say so:
FYI, this fact that you should not be using Serial-over-LAN via WiFi or VPN was further explained in the latest blog post on the Home Assistant website (which applies even though ibout Z-Wave):
@Ash.xiao ESPHome developers had to implement a custom solution for Protocol Buffers (commonly known as “Protobuf”) to serializing and buffer Z-Wave serial communcation in order to get a reliable Serial-over-IP tunnel connection over Wi-Fi:
@Ash.xiao please see replies here where Sonoff end-users have reporting to zha/zigpy developers that Sonoff multiprotocol is not working any good and zha/zigpy developers having to be the ones replying to each end-user explaining that using multi-protocol on a single adapter is not officially supported nor recommended, so users are on their own if they want to use such a unsupported experimental setup as well, and again they recommend just buying two adapters instead → Sonoff multiprotocol addon configuration issue · Issue #543 · zigpy/zha · GitHub
Quote: ”We do not support any Multiprotocol solutions anymore.” … ”I’d really recommend to avoid any Multiprotocol solutions and just get a second adapter. One for Zigbee, one for Thread.”
I would think this is in Sonoff interest as well as they could aell more adapters if all users only use didicated adapter for each protocol
@Ash.xiao wondering why we’re seeing the 7.4.5 EmberZNet with a novel device such as the MG24 and Max dongles. With 8.0.x and 8.1.x both available, and having tested both work just fine on the previous -E dongle, is Sonoff
Considering/evaluating the newer versions, if anything releasing them as beta?
Willing to enable developers to build firmware for it?
There was a similar conversation here with @Nerivec and it seems all that is needed is a manifest file such as this one - is it possible to provide it, for the MG and Max versions both?
I bought 4 of these during the Black Friday deal. Using them as one coordinator and 3 routers. I’m hoping for no more headaches with my Zigbee network. The latest coordinator firmware is 8.0.2 right now, but the router firmware is still at 7.5.0. My old Dongle-E currently has 8.0.2 router firmware.
Do you think it’s just a matter of time before they release 8.0.2 or a newer router firmware for the MG24?
But in reality I do not think it matters at this time as currently there are no known benefits to 8.0.x version over 7.x.x version for the Zigbee Router function.
Maybe when Silicon Labs release Zigbee 4.0 compatible firmware for these (probably as version 9.0.x) then it will start to become important (and if also ZHA and Zigbee2MQTT adds support for Zigbee 4.0 then)
Bootloader reset in Sonoff dongles has been supported for a very long time now! It works the same in new dongles using the universal-silabs-flasher rts_dtr reset target.
