Items in side bar can't be hidden
If I edit in the companion app the side bar, I can reorder the items, I can press the “+” to show hidden items again. But if I press “x”, nothing happens, the items are still displayed.
If I try the same with the browser on the android smartphone or with the browser on my PC everything wirks fine. I have read, that the might be some cache problems, so I stopped the app, cleared all caches, removed it and installed it again. No change.
This sounds like a problem with the companion app.
As I don’t use this function regularly I don’t know exactly, since when this behaviour happens, but I think it happened after intalling HA 2025.5. I know that this seems to be a contradiction to the feeling, that this is a problem of the app.
Companion app and HA are the actual version 2025.5.3
Do I something wrong? Is there anything I can try?
I have the same problem. Most likely a bug, I will wait for a fix
HA core 2025.6 contains the fix
