Iterate through json array to retrieve all attributes
Hello all, I was wondering if there’s a better way to do this:
rest:
  resource: https://periodic-table-elements-info.herokuapp.com/elements
    - name: 'hydrogen'
      json_attributes_path: $.[0]
      value_template: 'OK'
      json_attributes:
      - atomicNumber
      - symbol
      - atomicMass
      - atomicRadius
      - standardState
      - meltingPoint
      - boilingPoint
      - density
    - name: 'helium'
      json_attributes_path: $.[1]
      json_attributes:
      - atomicNumber
      - symbol
      - atomicMass
      - atomicRadius
      - standardState
      - meltingPoint
      - boilingPoint
      - density
    - name: 'lithium'
      json_attributes_path: $.[2]
      json_attributes:
      - atomicNumber
      - symbol
      - atomicMass
      - atomicRadius
      - standardState
      - meltingPoint
      - boilingPoint
      - density
So I’m using restful to pull periodic table data. Is there a way to loop the json array instead of defining a sensor for each element individually?
Thanks :slight_smile:
Were you ever able to figure out a solution, I’m stuck attempting the same thing.
