i have installed home assistant using snaps in raspberry pi os buster on raspberry pi zero 2 w. I am not able to install hacs and even add on option is missing in settings page. Next is it possible to upload our own UI and icons in home assistant. i installed home assistant using the command below
snap install --channel=2021.12 home-assistant-snap
- A Pi Zero 2W is not powerful enough for Home Assistant beyond basic testing
- Snaps is not a supported installation method
- That version is antiquated
- Only the “Home Assistant OS” and “Home Assistant Supervised” installation method allows to use Addons.
It is possible to open browser on the same device, is there any command to open browser in same device
You might be able to use wget or curl to retrieve data on the HA installation.
