Izone controller unavailable in HA integration
I have Mitsubishi HVAC ducted air conditioning system controlled by izone controller with 8 zones. Each zone has izone isense sensors for temperature and motion sensing. Home assistant auto discover izone integration and I can see all the zones in home assistant as devices/entities. When I toggle heat/cool button of each zone in home assistant, the izone app/zone controller responded and changes according to the toggle but this does not actually change the HVAC operation. However, izone controller entity is labelled unavailable in home assistant and that means that I can not switch on or off the HVAC from home assistant. Home assistant, izone controller and izone wifi bridge are all in same LAN. I rebooted izone wifi bridge and izone controller but this is not helping. I deleted and re-installed izone home assistant integration. izone controller is still labelled unavailable in home assistant and therefore I can not turn on or off the HVAC from home assistant. I will be grateful if someone can help fix this.
Thanks heaps.
