Hi there, the documentation of the passive BLE Monitor integration states that the JHT sensors are supported. However, the sensor ist not detected after installing and configuring the integration. Also manual entry in config.yaml did not help. I have Bluetooth Proxies, and also some Xiaomi sensors, which use the Xiaomi BLE integration, and they work fine. Also weird: The JHT sensor is detectet as “IBeacon tracker”.
How to troubleshoot this?
Same problem here. Did you ever find a solution? I’m also using Bluetooth proxy and a Jaalee JHT sensor
Depending on the models of your Jaalee JHT sensors, you might want to give the Theengs Gateway Add-On a try, or OpenMQTTGateway on an ESP32.
