Jablotron not responding
I have a problem with the Jablotron integration: it stops updating after a while. Each morning, the integration does not update a changing arm/disarm or PG status. However, the status suddenly updates later in the day. Does anyone know what could be causing this?
The only integrations I can find for that are Github ones. You will need to contact the site that you found this integration to get support. Someone here might see it but best to go to the source, you may find an issue there for this already or possibly a fix.
