I am looking to replace my pool pump with a variable-speed version. Currently leaning towards a Jandy VS FloPro 1.65 HP one. Reading through the specs, it appears to support remote control through a iQPUMP01.
Looking at the official integration (Jandy iAqualink - Home Assistant), I see another remote control device called the iAQUALINK 3.0.
Hoping someone can help me on this. Do I require both the iQPUMP01 and iAQUALINK device to integrate the pump into HA? If not and I only require the iQPUMP01, is this integrated with the official HA integration linked above?
I’ve read through all of Jandy’s website, and this is not in the least bit clear!
Same here, IQPUMP, despite raising to the iaqualink web site does not seem compatible with the plugin, it makes it crashing during its init phase in my case.
I was able to identify all the API calls to interact with the IQPUMP01:
Get the device-related data (Serial number, RPM, power consumption, temperature, global configuration)
Write / set a custom operation override RPM + duration
Stop the pump
Start the pump while resuming the default schedule
Read the schedules and understand how the scheduled associated data is pushed
Write the schedules
Using all of them allowed me to interact with my pump without any issue.
Now, I’m not a developer/don’t know Python (nor even I have yet migrated to HA ) and not able to modify the already existing Jandry module
If somebody has the skills and is willing to put a few stuff together, I’ll be more than happy to share what I have inventoried and be a beta tester.
Joacbe this would be great! I’d love to help, but it sounds like your skills already greatly exceed mine. If there’s something I can do please let me know
I know this is quite old, but I recently purchased a new Jandy pool pump system, chlorinator, and IQPUMP01. I’d definitely be interested in the data you’ve discovered to create something. Please reach out if you still have this.
Sorry, just seeing now all the posts following mine. Apologies not replying to them earlier (I have not received notifications from them being posted ).
I’ve shared all my discoveries on GitHub after receiving Robert’s request from there.
As said, unfortunately, I have 0 Python skills and I am still barely using HA (I’ve been waiting to move away from Jeedom to find a way to manage end-to-end my pool from it) so I don’t have yet a good understanding of how it works.
I loaded the iqpump integration, however it errors when I try to log in. I changed my pw and still get the “Unable to connect. Please check your credentials.”
I can use the pw to log in over the internet site and thru the app. Do you have any ideas that may get me connected?
