I have a ton of these dimmers through the house (Jasco = GE in Canada) that I setup when I first installed HA with the old integrated Z-Wave system. Since then, I have upgraded HA to the latest and transitioned to ZWaveJS. I am now trying to add two more of these dimmers, but a newer model. When I use inclusion mode, it detects the device and picks it up, but doesn’t populate properly. If I use the default inclusion mode, it doesn’t work at all, but if I switch to legacy, I get a partial inclusion. It doesn’t pickup the manufacturer or model. I have try re-interviewing to no avail. I have also removed/included several times. Most of my devices are using S2. I have an Aeotec Zwave stick with the latest firmware.
I have attached a screenshot of what the device looks like and also the logs. Any help is very much appreciated!
Blockquote
Subscribed to Z-Wave JS log messages…
2025-02-13T20:51:36.040Z CNTRLR « [Node 179] Received updated node info
2025-02-13T20:51:37.038Z CNTRLR « [Node 179] received CentralScene notification {
“nodeId”: 179,
“ccId”: “Central Scene”,
“ccCommand”: “0x03”
2025-02-13T20:51:37.354Z CNTRLR starting exclusion process…
2025-02-13T20:51:37.362Z CNTRLR The controller is now ready to remove nodes
2025-02-13T20:51:39.907Z CNTRLR handling remove node request (status = NodeFound)
2025-02-13T20:51:40.579Z CNTRLR handling remove node request (status = RemovingSlave)
2025-02-13T20:51:40.586Z CNTRLR handling remove node request (status = Done)
2025-02-13T20:51:40.590Z CNTRLR the exclusion process was stopped
2025-02-13T20:51:40.590Z CNTRLR Node 179 was removed
2025-02-13T20:51:41.033Z CNTRLR « [Node 062] Received updated node info
2025-02-13T20:51:46.198Z CNTRLR Starting inclusion process with strategy Default…
2025-02-13T20:51:46.206Z CNTRLR The controller is now ready to add nodes
2025-02-13T20:51:48.429Z CNTRLR stopping inclusion process…
2025-02-13T20:51:48.488Z CNTRLR The inclusion process was stopped
2025-02-13T20:51:50.635Z CNTRLR Starting inclusion process with strategy Security_S0…
2025-02-13T20:51:50.643Z CNTRLR The controller is now ready to add nodes
2025-02-13T20:52:12.471Z CNTRLR stopping inclusion process…
2025-02-13T20:52:12.529Z CNTRLR The inclusion process was stopped
2025-02-13T20:52:14.780Z CNTRLR « [Node 063] Received updated node info
2025-02-13T20:52:41.312Z CNTRLR Starting inclusion process with strategy Default…
2025-02-13T20:52:41.319Z CNTRLR The controller is now ready to add nodes
2025-02-13T20:52:42.654Z CNTRLR stopping inclusion process…
2025-02-13T20:52:42.713Z CNTRLR The inclusion process was stopped
2025-02-13T20:52:44.009Z CNTRLR Starting inclusion process with strategy Security_S0…
2025-02-13T20:52:44.017Z CNTRLR The controller is now ready to add nodes
2025-02-13T20:52:47.945Z CNTRLR handling add node request (status = NodeFound)
2025-02-13T20:52:48.883Z CNTRLR handling add node request (status = AddingSlave)
2025-02-13T20:53:01.955Z CNTRLR handling add node request (status = ProtocolDone)
2025-02-13T20:53:01.956Z CNTRLR finishing inclusion process…
2025-02-13T20:53:02.018Z CNTRLR The inclusion process was stopped
2025-02-13T20:53:02.020Z CNTRLR finished adding node 180:
basic device class: Routing End Node
generic device class: Multilevel Switch
specific device class: Unused
supported CCs:
· Z-Wave Plus Info (0x5e)
· Application Status (0x22)
· Association (0x85)
· Multi Channel Association (0x8e)
· Association Group Information (0x59)
· Multilevel Switch (0x26)
· Indicator (0x87)
· Transport Service (0x55)
· Version (0x86)
· Manufacturer Specific (0x72)
· Device Reset Locally (0x5a)
· Powerlevel (0x73)
· Configuration (0x70)
· Security 2 (0x9f)
· Supervision (0x6c)
· Central Scene (0x5b)
· Firmware Update Meta Data (0x7a)
controlled CCs:
2025-02-13T20:53:02.021Z CNTRLR » [Node 180] Assigning SUC return route…
2025-02-13T20:53:02.021Z CNTRLR » [Node 180] Deleting SUC return route…
2025-02-13T20:53:05.959Z CNTRLR [Node 180] Beginning interview - last completed stage: None
2025-02-13T20:53:05.960Z CNTRLR [Node 180] new node, doing a full interview…
2025-02-13T20:53:05.960Z CNTRLR » [Node 180] querying protocol info…
2025-02-13T20:53:05.970Z CNTRLR « [Node 180] received response for protocol info:
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2025-02-13T20:53:05.971Z CNTRLR [Node 180] Interview stage completed: ProtocolInfo
2025-02-13T20:53:05.973Z CNTRLR » [Node 180] querying node info…
2025-02-13T20:53:06.135Z CNTRLR « [Node 180] node info received
supported CCs:
· Z-Wave Plus Info
· Association
· Multilevel Switch
· Indicator
· Transport Service
· Version
· Powerlevel
· Configuration
· Security 2
· Supervision
· Central Scene
2025-02-13T20:53:06.136Z CNTRLR « [Node 180] node info received
supported CCs:
· Z-Wave Plus Info
· Association
· Multilevel Switch
· Indicator
· Transport Service
· Version
· Powerlevel
· Configuration
· Security 2
· Supervision
· Central Scene
2025-02-13T20:53:06.138Z CNTRLR [Node 180] Interview stage completed: NodeInfo
2025-02-13T20:53:06.138Z CNTRLR [Node 180] Interviewing Manufacturer Specific…
2025-02-13T20:53:06.139Z CNTRLR » [Node 180] querying manufacturer information…
2025-02-13T20:53:06.350Z CNTRLR « [Node 180] received response for manufacturer information:
manufacturer: Jasco Products (0x63)
product type: 0x4944
product id: 0x3434
2025-02-13T20:53:06.351Z CNTRLR [Node 180] Interviewing Version…
2025-02-13T20:53:06.351Z CNTRLR » [Node 180] querying the CC version for Version…
2025-02-13T20:53:06.558Z CNTRLR [Node 180] supports CC Version (0x86) in version 3
2025-02-13T20:53:06.558Z CNTRLR » [Node 180] querying node versions…
2025-02-13T20:53:06.771Z CNTRLR « [Node 180] received response for node versions:
library type: Enhanced Slave (0x03)
protocol version: 7.15
firmware versions: 1.25
hardware version: 1
2025-02-13T20:53:06.772Z CNTRLR » [Node 180] querying CC versions…
2025-02-13T20:53:06.772Z CNTRLR » [Node 180] querying the CC version for Basic…
2025-02-13T20:53:06.978Z CNTRLR [Node 180] supports CC Basic (0x20) in version 2
2025-02-13T20:53:06.979Z CNTRLR » [Node 180] querying the CC version for Z-Wave Plus Info…
2025-02-13T20:53:07.186Z CNTRLR [Node 180] supports CC Z-Wave Plus Info (0x5e) in version 2
2025-02-13T20:53:07.186Z CNTRLR [Node 180] skipping query for Application Status (0x22) because max implemen
ted version is 0
2025-02-13T20:53:07.187Z CNTRLR » [Node 180] querying the CC version for Association…
2025-02-13T20:53:07.396Z CNTRLR [Node 180] supports CC Association (0x85) in version 2
2025-02-13T20:53:07.397Z CNTRLR » [Node 180] querying the CC version for Multi Channel Association…
2025-02-13T20:53:07.606Z CNTRLR [Node 180] supports CC Multi Channel Association (0x8e) in version 3
2025-02-13T20:53:07.607Z CNTRLR » [Node 180] querying the CC version for Association Group Information…
2025-02-13T20:53:07.815Z CNTRLR [Node 180] supports CC Association Group Information (0x59) in version 3
2025-02-13T20:53:07.816Z CNTRLR » [Node 180] querying the CC version for Multilevel Switch…
2025-02-13T20:53:08.025Z CNTRLR [Node 180] supports CC Multilevel Switch (0x26) in version 4
2025-02-13T20:53:08.026Z CNTRLR » [Node 180] querying the CC version for Indicator…
2025-02-13T20:53:08.235Z CNTRLR [Node 180] supports CC Indicator (0x87) in version 3
2025-02-13T20:53:08.236Z CNTRLR » [Node 180] querying the CC version for Transport Service…
2025-02-13T20:53:08.446Z CNTRLR [Node 180] supports CC Transport Service (0x55) in version 2
2025-02-13T20:53:08.446Z CNTRLR » [Node 180] querying the CC version for Manufacturer Specific…
2025-02-13T20:53:08.661Z CNTRLR [Node 180] supports CC Manufacturer Specific (0x72) in version 2
2025-02-13T20:53:08.661Z CNTRLR » [Node 180] querying the CC version for Device Reset Locally…
2025-02-13T20:53:08.864Z CNTRLR [Node 180] supports CC Device Reset Locally (0x5a) in version 1
2025-02-13T20:53:08.865Z CNTRLR » [Node 180] querying the CC version for Powerlevel…
2025-02-13T20:53:09.076Z CNTRLR [Node 180] supports CC Powerlevel (0x73) in version 1
2025-02-13T20:53:09.076Z CNTRLR » [Node 180] querying the CC version for Configuration…
2025-02-13T20:53:09.286Z CNTRLR [Node 180] supports CC Configuration (0x70) in version 4
2025-02-13T20:53:09.287Z CNTRLR » [Node 180] querying the CC version for Security 2…
2025-02-13T20:53:09.496Z CNTRLR [Node 180] supports CC Security 2 (0x9f) in version 1
2025-02-13T20:53:09.496Z CNTRLR » [Node 180] querying the CC version for Supervision…
2025-02-13T20:53:09.706Z CNTRLR [Node 180] supports CC Supervision (0x6c) in version 1
2025-02-13T20:53:09.707Z CNTRLR » [Node 180] querying the CC version for Central Scene…
2025-02-13T20:53:09.916Z CNTRLR [Node 180] supports CC Central Scene (0x5b) in version 3
2025-02-13T20:53:09.917Z CNTRLR » [Node 180] querying the CC version for Firmware Update Meta Data…
2025-02-13T20:53:10.129Z CNTRLR [Node 180] supports CC Firmware Update Meta Data (0x7a) in version 5
2025-02-13T20:53:10.129Z CNTRLR » [Node 180] querying if Z-Wave Software Get is supported…
2025-02-13T20:53:10.335Z CNTRLR « [Node 180] Z-Wave Software Get is supported
2025-02-13T20:53:10.336Z CNTRLR » [Node 180] querying Z-Wave software versions…
2025-02-13T20:53:10.558Z CNTRLR « [Node 180] received Z-Wave software versions
2025-02-13T20:53:10.562Z CNTRLR [Node 180] No device config found
2025-02-13T20:53:10.563Z CNTRLR [Node 180] Interviewing Z-Wave Plus Info…
2025-02-13T20:53:10.563Z CNTRLR » [Node 180] querying Z-Wave+ information…
2025-02-13T20:53:10.774Z CNTRLR « [Node 180] received response for Z-Wave+ information:
Z-Wave+ version: 2
role type: AlwaysOnSlave
node type: Node
installer icon: 0x0604
user icon: 0x0600
2025-02-13T20:53:10.775Z CNTRLR [Node 180] Interviewing Indicator…
2025-02-13T20:53:10.775Z CNTRLR » [Node 180] scanning supported indicator IDs…
2025-02-13T20:53:10.977Z CNTRLR « [Node 180] supported indicator IDs: 80
2025-02-13T20:53:10.978Z CNTRLR » [Node 180] requesting current indicator value (id = 0x50)…
2025-02-13T20:53:11.195Z CNTRLR [Node 180] Interviewing Firmware Update Meta Data…
2025-02-13T20:53:11.196Z CNTRLR » [Node 180] Querying firmware update capabilities…
2025-02-13T20:53:11.411Z CNTRLR « [Node 180] Received firmware update capabilities:
firmware targets: 0
continues to function: undefined
supports activation: undefined
2025-02-13T20:53:11.412Z CNTRLR [Node 180] Interviewing Association…
2025-02-13T20:53:11.413Z CNTRLR » [Node 180] querying number of association groups…
2025-02-13T20:53:11.616Z CNTRLR « [Node 180] supports 3 association groups
2025-02-13T20:53:11.617Z CNTRLR » [Node 180] querying association group #1…
2025-02-13T20:53:11.826Z CNTRLR « [Node 180] received information for association group #1:
maximum # of nodes: 5
currently assigned nodes:
2025-02-13T20:53:11.827Z CNTRLR » [Node 180] querying association group #2…
2025-02-13T20:53:12.035Z CNTRLR « [Node 180] received information for association group #2:
2025-02-13T20:53:12.035Z CNTRLR » [Node 180] querying association group #3…
2025-02-13T20:53:12.246Z CNTRLR « [Node 180] received information for association group #3:
2025-02-13T20:53:12.246Z CNTRLR [Node 180] AssociationCC: delaying configuration of lifeline associations unti
l after Multi Channel Association interview…
2025-02-13T20:53:12.247Z CNTRLR [Node 180] Interviewing Multi Channel Association…
2025-02-13T20:53:12.247Z CNTRLR » [Node 180] querying number of multi channel association groups…
2025-02-13T20:53:12.454Z CNTRLR « [Node 180] supports 3 multi channel association groups
2025-02-13T20:53:12.455Z CNTRLR » [Node 180] querying multi channel association group #1…
2025-02-13T20:53:12.668Z CNTRLR « [Node 180] received information for multi channel association group #1:
currently assigned endpoints:
2025-02-13T20:53:12.669Z CNTRLR » [Node 180] querying multi channel association group #2…
2025-02-13T20:53:12.876Z CNTRLR « [Node 180] received information for multi channel association group #2:
2025-02-13T20:53:12.877Z CNTRLR » [Node 180] querying multi channel association group #3…
2025-02-13T20:53:13.085Z CNTRLR « [Node 180] received information for multi channel association group #3:
2025-02-13T20:53:13.086Z CNTRLR [Node 180] Checking/assigning lifeline groups: 1
supports classic associations: true
supports multi channel associations: true
2025-02-13T20:53:13.086Z CNTRLR [Node 180] Configuring lifeline group #1:
group supports multi channel: true
configured strategy: auto
must use node association: true
must use endpoint association: false
2025-02-13T20:53:13.087Z CNTRLR » [Node 180] Assigning lifeline group #1 with a node association via Association
CC…
2025-02-13T20:53:13.506Z CNTRLR [Node 180] Lifeline group #1 was assigned with a node association via Associat
ion CC
2025-02-13T20:53:13.507Z CNTRLR [Node 180] Interviewing Association Group Information…
2025-02-13T20:53:13.508Z CNTRLR » [Node 180] Association group #1: Querying name…
2025-02-13T20:53:13.720Z CNTRLR « [Node 180] Association group #1 has name “Lifeline”
2025-02-13T20:53:13.721Z CNTRLR » [Node 180] Association group #1: Querying command list…
2025-02-13T20:53:13.933Z CNTRLR » [Node 180] Association group #2: Querying name…
2025-02-13T20:53:14.160Z CNTRLR « [Node 180] Association group #2 has name “Group2 On/Off/Dim control”
2025-02-13T20:53:14.161Z CNTRLR » [Node 180] Association group #2: Querying command list…
2025-02-13T20:53:14.371Z CNTRLR » [Node 180] Association group #3: Querying name…
2025-02-13T20:53:14.600Z CNTRLR « [Node 180] Association group #3 has name “Group3 On/Off/Dim control”
2025-02-13T20:53:14.601Z CNTRLR » [Node 180] Association group #3: Querying command list…
2025-02-13T20:53:14.809Z CNTRLR » [Node 180] Association group #1: Querying info…
2025-02-13T20:53:15.018Z CNTRLR « [Node 180] Received info for association group #1:
info is dynamic: false
profile: General: Lifeline
2025-02-13T20:53:15.019Z CNTRLR » [Node 180] Association group #2: Querying info…
2025-02-13T20:53:15.232Z CNTRLR « [Node 180] Received info for association group #2:
profile: Control: Key 01
2025-02-13T20:53:15.233Z CNTRLR » [Node 180] Association group #3: Querying info…
2025-02-13T20:53:15.450Z CNTRLR « [Node 180] Received info for association group #3:
profile: Control: Key 02
2025-02-13T20:53:15.451Z CNTRLR [Node 180] Interviewing Multilevel Switch…
2025-02-13T20:53:15.451Z CNTRLR » [Node 180] requesting switch type…
2025-02-13T20:53:15.666Z CNTRLR « [Node 180] has switch type Down/Up
2025-02-13T20:53:15.669Z CNTRLR » [Node 180] requesting current switch state…
2025-02-13T20:53:15.877Z CNTRLR [Node 180] Interviewing Configuration…
2025-02-13T20:53:15.878Z CNTRLR » [Node 180] finding first configuration parameter…
2025-02-13T20:53:16.087Z CNTRLR » [Node 180] querying parameter #3 information…
2025-02-13T20:53:17.095Z CNTRLR « [Node 180] received information for parameter #3:
parameter name: LED Light Mode
value format: SignedInteger
value size: 1 bytes
min value: 0
max value: 3
default value: 0
is read-only: false
is advanced (UI): false
has bulk support: false
alters capabilities: false
2025-02-13T20:53:17.096Z CNTRLR » [Node 180] querying parameter #4 information…
2025-02-13T20:53:18.714Z CNTRLR « [Node 180] received information for parameter #4:
parameter name: Invert Switch
value size: 1 bytes
min value: 0
max value: 1
default value: 0
is read-only: false
2025-02-13T20:53:18.715Z CNTRLR » [Node 180] querying parameter #5 information…
2025-02-13T20:53:20.643Z CNTRLR « [Node 180] received information for parameter #5:
parameter name: 3-Way Type
value size: 1 bytes
min value: 0
max value: 1
default value: 0
is read-only: false
2025-02-13T20:53:20.644Z CNTRLR » [Node 180] querying parameter #16 information…
2025-02-13T20:53:22.437Z CNTRLR « [Node 180] received information for parameter #16:
parameter name: Switch Mode
value size: 1 bytes
min value: 0
max value: 1
default value: 0
is read-only: false
2025-02-13T20:53:22.438Z CNTRLR » [Node 180] querying parameter #19 information…
2025-02-13T20:53:23.872Z CNTRLR « [Node 180] received information for parameter #19:
parameter name: Alternate Exclus io
value size: 1 bytes
min value: 0
max value: 1
default value: 0
is read-only: false
2025-02-13T20:53:23.873Z CNTRLR » [Node 180] querying parameter #30 information…
2025-02-13T20:53:24.967Z CNTRLR « [Node 180] received information for parameter #30:
parameter name: Minimum Dim Thre hol
value size: 1 bytes
min value: 1
max value: 99
default value: 1
is read-only: false
2025-02-13T20:53:24.968Z CNTRLR » [Node 180] querying parameter #31 information…
2025-02-13T20:53:26.519Z CNTRLR « [Node 180] received information for parameter #31:
parameter name: Maximum Brightne ss Threhol
value size: 1 bytes
min value: 1
max value: 99
default value: 99
is read-only: false
2025-02-13T20:53:26.519Z CNTRLR » [Node 180] querying parameter #32 information…
2025-02-13T20:53:27.900Z CNTRLR « [Node 180] received information for parameter #32:
parameter name: Brightness Level
value size: 1 bytes
min value: 0
max value: 99
default value: 0
is read-only: false
2025-02-13T20:53:27.901Z CNTRLR » [Node 180] querying parameter #34 information…
2025-02-13T20:53:28.919Z CNTRLR « [Node 180] received information for parameter #34:
parameter name: LED Light Color
value size: 1 bytes
min value: 1
max value: 8
default value: 5
is read-only: false
2025-02-13T20:53:28.920Z CNTRLR » [Node 180] querying parameter #35 information…
2025-02-13T20:53:30.016Z CNTRLR « [Node 180] received information for parameter #35:
parameter name: LED Light Intens it
value size: 1 bytes
min value: 1
max value: 7
default value: 4
is read-only: false
2025-02-13T20:53:30.017Z CNTRLR » [Node 180] querying parameter #36 information…
2025-02-13T20:53:31.410Z CNTRLR « [Node 180] received information for parameter #36:
parameter name: Guidelight Mode Intensit
value size: 1 bytes
min value: 1
max value: 7
default value: 4
is read-only: false
2025-02-13T20:53:31.411Z CNTRLR » [Node 180] querying parameter #84 information…
2025-02-13T20:53:32.824Z CNTRLR « [Node 180] received information for parameter #84:
parameter name: Reset Factory De faul
value size: 1 bytes
min value: 0
max value: 1
default value: 0
is read-only: false
2025-02-13T20:53:32.825Z CNTRLR » [Node 180] querying parameter #3 value…
2025-02-13T20:53:33.037Z CNTRLR » [Node 180] querying parameter #4 value…
2025-02-13T20:53:33.247Z CNTRLR » [Node 180] querying parameter #5 value…
2025-02-13T20:53:33.455Z CNTRLR » [Node 180] querying parameter #16 value…
2025-02-13T20:53:33.665Z CNTRLR » [Node 180] querying parameter #19 value…
2025-02-13T20:53:33.878Z CNTRLR » [Node 180] querying parameter #30 value…
2025-02-13T20:53:34.094Z CNTRLR » [Node 180] querying parameter #31 value…
2025-02-13T20:53:34.377Z CNTRLR » [Node 180] querying parameter #32 value…
2025-02-13T20:53:34.587Z CNTRLR » [Node 180] querying parameter #34 value…
2025-02-13T20:53:34.802Z CNTRLR » [Node 180] querying parameter #35 value…
2025-02-13T20:53:35.009Z CNTRLR » [Node 180] querying parameter #36 value…
2025-02-13T20:53:35.218Z CNTRLR » [Node 180] querying parameter #84 value…
2025-02-13T20:53:35.428Z CNTRLR [Node 180] Interviewing Central Scene…
2025-02-13T20:53:35.429Z CNTRLR » [Node 180] Querying supported scenes…
2025-02-13T20:53:35.637Z CNTRLR « [Node 180] received supported scenes:
# of scenes: 2
supports slow refresh: true
2025-02-13T20:53:35.638Z CNTRLR » [Node 180] Enabling slow refresh capability…
2025-02-13T20:53:35.850Z CNTRLR [Node 180] Interview stage completed: CommandClasses
2025-02-13T20:53:35.851Z CNTRLR [Node 180] Interview stage completed: OverwriteConfig
2025-02-13T20:53:35.852Z CNTRLR [Node 180] Interview completed
2025-02-13T20:53:35.852Z CNTRLR [Node 180] The node is ready to be used
2025-02-13T20:53:39.259Z CNTRLR « [Node 180] received CentralScene notification {
“nodeId”: 180,
“ccCommand”: “0x03”
