Javascript_version: latest affects iOS App
I tried in 0.59.2 hassio
frontend:
  javascript_version: latest
I found that this affects the iOS App that I use on my iPhone.
The graphs for temperature do not render for my generic thermostat component.
The rendering is unreliable now. Works on a second try.
The “javascript_version: latest” option stops rendering consistently.
Thank you @GrahamS for figuring this out. Have the same issue and first thought it was an adblocker on iOS causing the issue.
For now I disabled the javascript_version issue in configuration.yaml.
geoffrey
You will find that HA 0.60.0 has the same problem.
To fix add to configuration.yaml
frontend:
  javascript_version: es5
This is also true for Safari on OS X
Thanks @GrahamS for the heads up. Did the update to 0.60 and adjusted the configuration. Works like a charm.
