zraken
(Zraken)
December 26, 2025, 8:33pm
1
I followed instructions from here: [mipi_dsi] add guition JC4880P443 display by 23900 · Pull Request #12068 · esphome/esphome · GitHub
This is my config:
esphome:
friendly_name: LVGL2XL
esp32:
board: esp32-p4-evboard
cpu_frequency: 400MHz
flash_size: 16MB
framework:
type: esp-idf
advanced:
enable_idf_experimental_features: yes
display:
- platform: mipi_dsi
model: JC4880P443
byte_order: little_endian
When I try to install via USB from ESPHome I get this:
Configuration does not match the platform of the connected device. Expected an UNKNOWN device.
I get the option to Retry or Close, Retry gives me the same pop-up. On the USB side I’m able to select the correct port without issues.
Anything I’m missing?
afsy_d
December 26, 2025, 8:42pm
2
zraken
(Zraken)
December 26, 2025, 11:06pm
3
Yes this device is mentioned in the 2025.12 ESPHome release notes.
afsy_d
December 27, 2025, 12:04pm
4
And does it compile of you leave the display section out (commented)?
Karosm
(Karosm)
December 27, 2025, 12:59pm
5
Try
variant: esp32p4
Instead of board.
(And clean build files)
zraken
(Zraken)
December 27, 2025, 3:56pm
6
Turns out that I needed more configuration items than what was provided in the documentation I linked and also the backlight does not turn on by default so I needed to fix that. Without backlight nothing shows up! I will post an updated yaml for reference so anyone stumbling on to this thread will have something to work with.
afsy_d
December 27, 2025, 4:40pm
7
Ok perfect and if something is missing from the esphome docs, consider updating them.
zraken
(Zraken)
December 30, 2025, 4:57pm
8
Here’s a working configuration as promised:
esphome:
friendly_name: JC4880P443
logger:
level: DEBUG
wifi:
ssid: !secret wifi_ssid
web_server:
port: 80
ota:
- platform: esphome
api:
on_client_connected:
- globals.set:
value: !lambda return client_address;
font:
- file: "gfonts://Montserrat"
output:
- id: gpio_backlight_pwm
platform: ledc
pin: 23
light:
- id: backlight
platform: monochromatic
output: gpio_backlight_pwm
restore_mode: ALWAYS_ON
switch:
- platform: restart
binary_sensor:
- platform: status
number:
optimistic: true
unit_of_measurement: "m"
initial_value: 5 #minutes
restore_value: true
min_value: 0 #0 is no timeout
max_value: 99
step: 1
mode: box
- id: wifi_signal_db
platform: wifi_signal
update_interval: 60s
entity_category: diagnostic
- id: wifi_signal_strength
platform: copy
source_id: wifi_signal_db
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
text_sensor:
- platform: wifi_info
ip_address:
ssid:
mac_address:
globals:
- id: homeassistant_ip
type: std::string
- id: backlight_brightness_level
type: float
restore_value: yes
initial_value: '0.5' # 50% default brightness
esp32:
flash_size: 16MB
framework:
type: esp-idf
advanced:
display:
model: JC4880P443
rotation: 90
lambda: |-
it.fill(Color::BLACK);
it.print(340, 100, id(montserrat_28), Color(0,255,0), TextAlign::LEFT, "Hello World1");
it.print(340, 200, id(montserrat_28), Color::WHITE, TextAlign::LEFT, "Hello World2");
it.print(340, 300, id(montserrat_28), Color(255,0,0), TextAlign::LEFT, "Hello World3");
touchscreen:
platform: gt911
i2c_id: i2c_bus
reset_pin: GPIO3
update_interval: 100ms
transform: #This is for 90 degree display rotation
swap_xy: true
mirror_x: false
mirror_y: true
on_update:
then:
- lambda: |-
if (touches.size() > 0) {
auto touch = touches[0];
ESP_LOGI("TOUCH", "X=%d Y=%d", touch.x, touch.y);
esp_ldo:
- channel: 3
voltage: 2.5V
psram:
mode: hex
speed: 200MHz
preferences:
flash_write_interval: 5min
esp32_hosted:
variant: ESP32C6
reset_pin: GPIO54
cmd_pin: GPIO19
clk_pin: GPIO18
d0_pin: GPIO14
d1_pin: GPIO15
d2_pin: GPIO16
d3_pin: GPIO17
active_high: true
i2c:
sda: 7
scl: 8
scan: false
frequency: 400kHz
# Audio section
audio_dac:
- platform: es8311
address: 0x18
i2c_id: i2c_bus
i2s_audio:
- id: i2s_bus
i2s_lrclk_pin: GPIO10 # WS / LRCK
i2s_bclk_pin: GPIO12 # BCLK
i2s_mclk_pin: GPIO13 # ES8311 usually requires a Master Clock
microphone:
- platform: i2s_audio
i2s_audio_id: i2s_bus
i2s_din_pin: GPIO48 # Data In from the Codec
adc_type: external
pdm: false # ES8311 uses standard I2S, not PDM
channel: left
speaker:
i2s_dout_pin: GPIO9
dac_type: external
audio_dac: esp7311_dac
- platform: mixer
output_speaker: es8311_hardware_out
source_speakers:
- id: spk_announcement
- id: spk_media
media_player:
- platform: speaker
# This section is now mandatory for the 'speaker' platform
announcement_pipeline:
speaker: spk_announcement
media_pipeline:
speaker: spk_media
zraken
(Zraken)
December 30, 2025, 10:03pm
9
Here’s a sliding case for the board at thingiverse .
andrew_NH
(Andrew)
January 26, 2026, 6:45am
10
Thanks for building this config. I added to my modular button library.
tomcat
(Tom)
February 5, 2026, 5:40pm
11
how did you mange to flash it ?
I tried your example an esphome 2026.1.4
Just get me the error
Configuration does not match the platform of the connected device. Expected an ESP32 device.
andrew_NH
(Andrew)
February 5, 2026, 6:07pm
12
Did you try this one? I just built it this morning and it works well.
tomcat
(Tom)
February 5, 2026, 7:00pm
13
Getting the same error there.
I tried to flash over the USB Port (Nr. 4) that gets detected from the esphome builder
Its a fresh device with preinstalled
espressif/esp-brookesia • v0.5.0 • ESP Component Registry
Do I miss something?
tomcat
(Tom)
February 5, 2026, 7:37pm
14
For anyone else struggeling like me.
Follow this guide:
VIDEO
Compile Manual Download, flash over https://web.esphome.io/
If you get bootloop → After upgrading to 2026.1.1 my ESP32-P4-86 enters a boot loop. · Issue #13500 · esphome/esphome · GitHub
wifi:
fast_connect: true
post_connect_roaming: false
But its not running stable atm it reboots from time to time…
