Jinja behavior change? Accessing undefined attributes causes error
I am pretty sure that the following code
{% set m = { 'attribute': 'value' }%}
{{ 'yes' if m.attribute == 'value' else 'nope' }}
{{ 'yes' if m.not_an_attribute == 'value' else 'nope' }}
used to print
yes
nope
But since I updated to 2022.5 it seems to produce an error:
UndefinedError: 'dict object' has no attribute 'not_an_attribute'
Is this expected? Am I mistaken? What’s the cleanest way to achieve the desired result with the least amount of code? Is this the least verbose way to guard against undefined attributes?
{{ 'yes' if m.not_an_attribute is defined and m.not_an_attribute == 'value' else 'nope' }}
Thanks!
on 2022.4.7 here
You’re not. In the past this worked fine:
{{ states.binary_sensor
  |selectattr('attributes.device_class', 'in', ['motion', 'presence', 'window', 'door', 'opening', 'vibration'])
  |selectattr('state', 'in', ['on', 'opening', 'closing'])
  |map(attribute='name') |join('\n') }}
Now I get
UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'device_class'
Did you raise an issue?
Ah, cool:
