Jinja: selectattr & map attribute
Basically I would like to filter Twitch entities by “game”. Now I have the problem that I only get Undefined results with this example template:
{{ states
   |selectattr('entity_id','in', integration_entities('twitch'))
   |map(attribute='game')
   |list }}
When I remove the map line I can clearly see that the game attribute exists with a valid value. The same with any other attribute.
Originally I would like to achieve something like this
{{ states
   |selectattr('game','eq','Just Chatting')
   |count }}
What is wrong here?
{{ expand(integration_entities('twitch'))
   | selectattr('attributes.game', 'eq', 'Just Chatting')
   | list | count }}
Thank you!
The expand function seems very powerful. The solution was attributes.xxxxx.
Honostly I already didn’t got the difference between entity_id and a “real” attribute. And why selectATTR is not fetching “attributes” directly.
I still have to learn a lot. ^^
