JupyterLab not wanting to start
Hey fellow JupyterLab enthusiasts using it under Home Assistant! I’m reaching out for some help and guidance.
I’m having a bit of trouble getting JupyterLab to start, and I was hoping someone might be able to lend a hand.
I’ve included the logs below - I’d be super grateful if someone could take a look and offer some insight.
I’ve tried a few troubleshooting steps already, but I’m stumped. Here are the logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: JupyterLab
 Create documents containing live code, equations, visualizations, and explanatory text
 Add-on version: 0.15.9
 You are running the latest version of this add-on.
 System: Home Assistant OS 14.2  (amd64 / qemux86-64)
 Home Assistant Core: 2024.12.5
 Home Assistant Supervisor: 2025.02.4
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[15:12:02] INFO: Configuring timezone (Europe/Bucharest)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-system-packages: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-jupyter: starting
s6-rc: info: service init-system-packages successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-jupyter successfully started
s6-rc: info: service init-notebooks: starting
s6-rc: info: service jupyter: starting
s6-rc: info: service jupyter successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[15:12:02] INFO: Starting the Jupyter server...
[15:12:02] WARNING: Not updating Home Assistant notebook!
[15:12:02] WARNING: You have made local changes, which we will not overwrite.
fatal: cannot change to '/config/notebooks//bokeh-examples': No such file or directory
fatal: cannot change to '/config/notebooks/bokeh-examples': No such file or directory
s6-rc: warning: unable to start service init-notebooks: command exited 128
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service nginx: stopping
[15:12:02] INFO: Service NGINX exited with code 256 (by signal 15)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service jupyter: stopping
s6-rc: info: service init-nginx successfully stopped
[15:12:02] INFO: Service JupyterLab exited with code 256 (by signal 15)
s6-rc: info: service jupyter successfully stopped
s6-rc: info: service init-system-packages: stopping
s6-rc: info: service init-jupyter: stopping
s6-rc: info: service init-system-packages successfully stopped
s6-rc: info: service init-jupyter successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Thanks in advance for your help and expertise - I really appreciate it!
I solved it guys with VSCode. I downloaded all my files and then removed all the files in the /notebook folder. After that i uninstalled and reinstalled the Add-on, and copied back all of my deleted files. Future somebody Never Delete the Bokeh folder!!! and don’t miss any file when trying this method!
