Just a big clock
#6
It is here if you are still interested.
#7
Hi JT,
I have a special request…bc I’m barely js literate. I can read some but writing it is over my head.
I dig your clock, but I don’t need the seconds and I was hoping to request a change to the font and background pic.
A dream come true would be with a weather widget…so:
https://www.xda-developers.com/animated-flip-htc-sense-clock-ported-from-desire-hd/
But I could live without the weather.
I love this flip clock that was on the HTC HD2 back in the day.
Could you help out with the heavy lifting (js)? I could do the background mockup. It’s basically a dark gray or black semi transparent background with the white squares where the time font should be overlayed.
#8
The time display in the clock I posted above came from a sensor.local_time, I also removed second from my local_time since:
    sensors:
        local_time:
        value_template: "{{ as_timestamp(now()) | timestamp_custom('%-I:%M') }}"
        entity_id: sensor.time
%-I display, i.e. 3:12, use %H instead if you want 03:12.
For the weather widget, if you look at the 2nd banner badge (version 2.1 here ):
That has weather icon and temperature, same idea can be used for weather widget/clock. I used - type: state-icon with sensor.pws_weather_1d from WUnderground but their icon won’t scale any bigger though.
Hope that helps.
#9
The ‘value_template’ …where does this go? In your config.yaml?
Are you running home assistant or hass.io?
#10
Running Hassbian on Ubuntu. The value_template part should be in the configuration.yaml, sensor section.
#11
Ah. Hmm. I’m running homeassistant…
#12
Should be the same.
#13
the value template kills my config.yaml
#14
Would you please show your code and any error from log?
#15
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'time_date'
      - 'time_utc'
^^this works
    sensors:
      local_time:
        value_template: "{{as_timestamp(now()) | timestamp_custom('%-I:%M %p')}}"
      local_date:
        value_template: "{{as_timestamp(now()) | timestamp_custom('%A %B %-d')}}"
        entity_id: sensor.date
^^this has no effect
#16
Hmm, works for me:
So sensor.local_time did not show anything for you? How about sensor.time, is it showing anything?
#17
sensor.time works for me.
Question: on mobile, the font size is very small. Is there a way to increase the font size for smaller resolutions?
#18
Depends what card you are using, in picture-elements, for example, you can try to increase the font size in the state-label, style, font-size. Screen size creatures a different challenge, you may want to test out different units to see what works best, like %, vw, hw.
#19
Ok, I think using % will be solve my issue.
#20
06
With sensor.local_time the time value only appears as a hyphen.
#21
Would you please show your picture-elements code for this?
#22
- type: picture-elements
  image: /local/clock_template.png
  elements:
  - type: state-label
    entity: sensor.time
#23
Did you have any style: line after entity: sensor.time?
#24
indeed, I do.
    style:
      top: 50%
      left: 50%
      font-size: 15vw
      color: black #dk gray
      filter: opacity(70%)
#25
Last thing I can think of is comment out the image: to test.
If you still can’t even see sensor.time, there is something else wrong.
