Just lost remote access
Hello! Today I opened up Home Assistant app and see red issue “could not connect to the server”
I tried to open it locally and everything is fine. Duckdns works
tried to restart add-on and that did not help. Restart of Home Assistant did not help too.
How should I fix that?
In logs I can see couple z-wave lines like:
Z-Wave node 3 not ready after 30 seconds, continuing anyway
And what I don’t know what it is:
Fri Feb 07 2020 07:23:38 GMT+0300 (Москва, стандартное время)
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 415, in _async_add_entity
    raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: automation.themes_enable_night_theme. Platform automation does not generate unique IDs
ok, nasty issue
my internet provider sucks. I am not getting the same IP address in router settings and when I check myip. So I had to spend more money on their services to have static IP (for it to be reacheble)
And yes, now everything works
sorry for spam
if you take a look at your 1st and 3rd picture - its the same.
Forget about that 2nd picture - thats your private IP…
You probably shouldn’t post your public IP on here…
Thank you. But it has already changed when I posted it.
