Just updated to version .88 where's the www folder?
i am running this in docker
You need to manually create the www folder, under /usr/share/hassio/homeassistant, if you need to make use of it.
and you have to restart home assistant after you create it as well
my man, thanks for the heads up, i was just gonna say, it aint workin!
so I am trying to do a presence card, but it doesn’t appear to show the image, i want it to display my picture if i am home, /local/david.png works, but not if im using it as an entity
post the code you are entering
