Keep getting failed connection - motioneye
Can someone please help me? We’re wanting to add motioneye onto home assistant but cannot pass the initial setup. It keeps saying : “Failed Connection”. I’ve inputted many different URL without success. It there something missing? A step that needs to happen?
Thank you for your time.
Hey I’m having the same issue, I’m hosting the motioneye server on a different LXC on my proxmox server and when inserting the local ip it doesnt work. Both are connected to my tailscale network but no luck using that ip either.
Edit:
When I use the url in my web browser it does work and connect then when copying the url to my home assistant instance (on the same network) it does not connect. The passwords I set up just before this and have checked that they are correct. Hope someone is willing to help.
