Sync Brightness to Z-Wave Attribute v1.0
This blueprint allows you to easily create/maintain an automation that links the state of multiple entities:
- set the brightness of any Z-Wave dimmer switch entity, it will set the custom brightness z-wave attribute to that brightness.
- For Zooz, this is Custom Brightness.
- For Leviton, this is Initial Brightness.
NOTE: You can select any device and this script will not verify what you provide is accurate, but it will fail if the device is not compatible.
CHANGELOG:
- 1.0: (2025-01-13)
- First official release
