Hi guys,
I was experimenting with both integrations openai and the extended one and they are awesome
One thing i noticed and i will explain it using an actual example
i have three led strips zigbee from INNR that work like magic, if i ask normal chatgpt (openai) i want to color them to match France’s Flag for Ex, it automatically by itself color each one with one of the colors of the french flag and no need to specifiy each one
-if i ask the same of Extended, it either says it did it with no actual change, sometimes it change of the lights each time correctly while no change to the others, sometimes it respond with no light.x.x was found,
so i have to specify which light to which color so that it does it
also no control to light temperature or brightness whatsoever, so openai here works intelligently
on the other hand, normal openai has issues with my security system to just change the modes (unless i use a script) while the extended just do it without an effort,
i am trying to find a way to either make one of them better than the other or to try to have some quires of mine to go to one and some to go to the other but i had no luck
anyone faced one of these issues before ?
