I’ve setup Keymaster, got the integration up and running, connected my locks, but none of the keymaster files are showing up in the packages folder. I’m seeing issues when trying to manage lock codes that’s saying the status of the locks is unavailable. If I go into File Editor, I see files under ‘Custom Components’ → ‘Keymaster’ -->‘lovelace’.
- In the configuration.yaml file I’ve added the required code.
- In the file structure, I created a packages folder in the same location as the configuration.yaml file
- I’ve downloaded and installed all 4 dashboard files (auto-entities, fold-entity-row, card-tools, and number box) per the instructions.
- I’ve not run into any other issues until I started trying to manage the lock codes.
Is there a way to reconfigure keymaster to point all files to the packages folder? If I’m able to make that happen, I think that’ll fix the overall issue I’ve had.
