šŸ” KidsChores – Family Chore Management Integration
—- Update - It is working fine now, I missed the capitalization in one of the name changes…. Leaving this post in case someone else has the same self induced issue. Thank you!
I finally had a little bit of time to start looking at this, but I think your thought process and the work put in is pretty amazing so far. There is a lot more complexity to managing it than what you would think when you say ā€œKid chores.ā€ :slight_smile: In getting the integration setup, I have a couple of comments and questions about how the dates work for chores, specifically the recurring chores, but I need to play around with it a little to provide good feedback.
In the meantime, can you double check the yaml you listed for the dashboard? I know there are a couple of custom cards needed, which I added the ones I didn’t have. Additionally, I made those adjustments for faros, at the same time I replaced all of the variation of ā€œkid name, kid_name, etc.ā€
I tried troubleshooting, but the issue seems to be with the way template is being used in the auto-entities card. Are you sure it is formatted properly? I tried to narrow the card just down to that and it doesn’t seem right.
Thanks for all your work on this!
@ccpk1 Glad you were able to sort it out.
Thank you for the comments.
About the chore setup and the recurring days that’s something that I have to have a deeper look into. My initial setup may need some rework to make it more clean and useful. I will try to get it reset on the day set and if it has a recurring period set, reset to the next day/week or month.
My initial idea was to set chores with a due date, and after I thought about the recurring periods, so some things might need some improvement.
I will try to get it revised for next releases.
Cheers,
** UPDATE - If you are interested in an updated dashboard with additional features and more detailed instructions, you can look here: Introducing the KidsChores and Rewards Dashboard
As I dug in more to this more, there is a lot of good work and creativity to get this far along. Really good work!
As you saw in my earlier post, I had some trouble with the dashboards, and even when I got them working, they weren’t formatting as nicely as was displayed in your example. I made quite a few adjustments to formatting and the templates to hopefully simplify some things and better handle some errors that were showing up because some of the new entities didn’t have values when I first setup the dashboard. I also broke out two separate cards which helped me with some testing. One of the cards is for the kid, and the other for the parent. Below are some pictures as well as the code:
To use these, find and replace the following words ā€œPointsā€ and ā€œpointsā€ with whatever you are using. Then find and replace the kids name by find and replace ā€œPAYTONā€, ā€œPaytonā€, and ā€œpaytonā€ being sure to match case.
type: grid
square: false
columns: 1
cards:
  - type: heading
    heading: PAYTON
    heading_style: title
  - type: grid
    square: false
    columns: 2
    cards:
      - type: entity
        entity: sensor.payton_points
        unit: Points
      - type: custom:mushroom-entity-card
        entity: sensor.payton_highest_badge
        layout: vertical
        primary_info: state
        secondary_info: none
        fill_container: true
      - type: tile
        entity: sensor.payton_total_chores_completed
        name: Total Chores Completed
      - type: tile
        entity: sensor.payton_chores_completed_today
        name: Chores Completed Today
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.payton_points
    hours_to_show: 168
    group_by: date
    smoothing: false
    show:
      state: false
      icon: false
  - type: heading
    icon: ""
    heading: Claim Chores (Hold to Claim)
  - type: custom:auto-entities
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
        {%- set Kid_name = 'Payton' -%}  {# Define the kid's name dynamically #}
        {% for state in states.button -%}
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_claim_chore_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_claim_chore_')[1] -%}
            {%- set sensor_id = 'sensor.' + Kid_name | lower + '_status_' + sensor_suffix -%}
            {%- set secondary = 'Unknown' if state.state in ['unknown', 'unavailable', 'error'] else '' -%}
            {%- if not secondary and state.state | float(default=0) > 0 -%}
              {%- set delta = now().timestamp() - as_timestamp(state.state) -%}
              {%- set secondary =
                '%.0f minutes ago' % (delta / 60) if delta < 3600 else
                '%.0f hours ago' % (delta / 3600) if delta < 86400 else
                '%.0f days ago' % (delta / 86400)
            {%- endif -%}
                'type': 'custom:mushroom-template-card',
                'entity': state.entity_id,
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Claim Chore: ')[1],
                'secondary': secondary,
                'icon': state.attributes.icon,
                'icon_color': (
                  'green' if states(sensor_id) == 'approved' else
                  'yellow' if states(sensor_id) == 'partial' else
                  'orange' if states(sensor_id) == 'claimed' else
                  'red' if states(sensor_id) == 'overdue' else
                  'grey'
                'tap_action': {
                  'action': 'more-info'
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {%- endfor %}
    sort:
      method: friendly_name
  - type: heading
    icon: ""
    heading: Redeem Rewards (Hold to Redeem)
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: >-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_redeem_reward_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_redeem_reward_')[1] -%}
            {%- set sensor_id = 'sensor.' + Kid_name | lower + '_reward_status_' + sensor_suffix -%}
            {%- set cost = state_attr(sensor_id, 'cost') -%}
            {%- set claim_sensor_id = 'sensor.' + Kid_name | lower + '_' + sensor_suffix + '_claims' -%}
            {%- set claims = states(claim_sensor_id) | string if states(claim_sensor_id) != 'unknown' else 'N/A' -%}
            {%- set approvals_sensor_id = 'sensor.' + Kid_name | lower + '_' + sensor_suffix + '_approvals' -%}
            {%- set approvals = states(approvals_sensor_id) | string if states(approvals_sensor_id) != 'unknown' else 'N/A' -%}
            {%- set secondary = 'Cost: ' + (cost | string if cost else 'N/A') + '\n' + 'Claims: ' + claims + '\n' + 'Approved: ' + approvals-%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Redeem Reward: ')[1],
                'multiline_secondary': 'false',
                'icon_color': 'blue',
                'tap_action': {
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {% endfor %}
    sort:
type: grid
square: false
columns: 1
cards:
  - type: heading
    heading: PAYTON PARENT
  - type: grid
    square: false
    columns: 2
    cards:
      - type: entity
        unit: Points
        layout: vertical
        primary_info: state
      - type: tile
      - type: tile
    entities:
    hours_to_show: 168
    group_by: date
    smoothing: false
    show:
      state: false
      icon: false
  - type: heading
    heading: Chore Status
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
        {%- set Kid_name = 'Payton' -%}  {# Define the name dynamically #}
        {% for state in states.sensor -%}
          {%- if state.entity_id.startswith('sensor.' + Kid_name | lower + '_status_') -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Status - ')[1],
                'secondary': (
                  'Approved' if state.state == 'approved' else
                  'Claimed' if state.state == 'claimed' else
                  'Pending' if state.state == 'pending' else
                  'Partial' if state.state == 'partial' else
                  'Due' if state.state == 'overdue' else
                  'Pending'
                'icon_color': (
                  'green' if state.state == 'approved' else
                  'orange' if state.state == 'claimed' else
                  'grey' if state.state == 'pending' else
                  'yellow' if state.state == 'partial' else
                  'red' if state.state == 'overdue' else
                  'grey'
                'tap_action': {
          {%- endif -%}
        {%- endfor %}
      exclude: []
    sort:
  - type: heading
    icon: ""
    heading: Approve Chores (Hold to Approve)
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: >-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_approve_chore_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_approve_chore_')[1] -%}
              {%- set secondary =
            {%- endif -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Approve Chore: ')[1],
                'icon_color': (
                  'grey'
                'tap_action': {
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {%- endfor %}
    sort:
  - type: heading
    icon: ""
    heading: Disapprove Chores (Hold to Disapprove)
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_disapprove_chore_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_disapprove_chore_')[1] -%}
              {%- set secondary =
            {%- endif -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Disapprove Chore: ')[1],
                'icon_color': (
                  'grey'
                'tap_action': {
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {%- endfor %}
    sort:
  - type: heading
    icon: ""
    heading: Approve Rewards (Hold to Approve)
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_approve_reward_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_approve_reward_')[1] -%}
            {%- set secondary = 'Cost: ' + (cost | string if cost else 'N/A') -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Approve Reward: ')[1],
                'icon_color': (
                  'grey'
                'tap_action': {
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {%- endfor %}
    sort:
  - type: heading
    icon: ""
    heading: Disapprove Rewards (Hold to Disapprove)
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: >-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_disapprove_reward_') -%}
            {%- set sensor_suffix = state.entity_id.split('button.' + Kid_name | lower + '_disapprove_reward_')[1] -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Disapprove Reward: ')[1],
                'icon_color': (
                  'grey'
                'tap_action': {
                'hold_action': {
                  'action': 'toggle'
          {%- endif -%}
        {%- endfor %}
    sort:
  - type: heading
    icon: ""
    heading: Penalties
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
          {%- if state.entity_id.startswith('button.' + Kid_name | lower + '_apply_penalty_') -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' - Apply Penalty: ')[1],
                'tap_action': {
                  'action': 'toggle'
                'hold_action': {
          {%- endif -%}
        {%- endfor %}
    sort:
  - type: heading
    icon: ""
    heading: Manual Points
    card:
      square: false
      type: grid
      columns: 2
    card_param: cards
    filter:
      template: |-
          {%- if state.entity_id | regex_match("^button\\." + Kid_name | lower + "_\\d+_points(?:_\\d+)?$", ignorecase=False) -%}
                'primary': state.attributes.friendly_name.split(Kid_name + ' ')[1],
                'tap_action': {
                  'action': 'toggle'
                'hold_action': {
          {%- endif -%}
        {%- endfor %}
    sort:
      method: domain
      numeric: true
      ignore_case: false
      reverse: false
grid_options:
  columns: full
  rows: 8
I’m guessing your time is primarily focused on the backend work at the moment, so my goal was just to make some iterative improvements that hopefully help others more easily jump in to try it out. I think it is well designed; it just takes a little while to understand concepts of how you’re handling everything. I can definitely tell there is a lot of potential for improving.
I also made some notes while I was trying it out. I will put them in this post for now, but if you are at a point you want to start logging them on github, happy to do that:
Issues
  1. Chore Deletion
  • Problem: When a chore is deleted, the entities are not automatically removed.
  • Workaround: Manually delete the entities to prevent them from appearing on dashboards.
  1. Date Field Requirement
  • Problem: When managing chores, the date field must be clicked and selected every time. Not selecting it prevents submission, but the error is subtle and only noticeable after repeated submission attempts.
  • Workaround: Ensure you select the date field during creation or updates. Consider adding a note or warning to remind users.
  1. Claim Chore Button
  • Problem: When claiming a chore, the sensor status for that chore does not update to ā€œclaimed.ā€ Instead, it remains as ā€œoverdue.ā€ However, it is still possible to approve the claim. (This seems to work correctly for rewards.)
  1. Disapproving Chores/Rewards
  • Problem: When disapproving a chore or reward, the claim count does not decrement.
  • Note: This behavior might be by design and requires clarification.
  1. Manual Points Tracking
  • Problem: Manual points are displayed correctly in the max_points_ever sensor, but they do not appear in the points_earned sensors.
  • Note: This might also be by design and requires clarification.
  1. Overdue Chore Timing
  • Problem: Chores are marked as ā€œoverdueā€ even when the due time is later in the day (e.g., 9 PM).
Comments
  • Clarity on Dates and Recurring Activities: The process for managing dates and recurring activities needs more explanation or documentation.
  • Understanding kid_state vs global_state: There needs to be clearer guidance on how these states are used or differentiated.
  • Shared Chores:
    • Observation: When setting up a chore, at least one kid must be selected. Initially, I assumed leaving it blank would create a ā€œshared choreā€ for all kids.
    • Suggestion: No system changes needed; however, an FAQ or description update in the form could clarify this behavior.
  • Observation: I’m not sure if there is value in supporting fractional points.
    • Suggestion: I notice that points in the dashboard are showing with a decimal. Unless there is a specific need to support partial points, I’d recommend limiting it to whole numbers for simplicity.
Future Feature Requests
  1. Ad-Hoc Chores
  • Request: Allow a type of chore that doesn’t have a specific due date. Parents could assign a date later for tasks that aren’t time-sensitive (e.g., ā€œGet your room ready for guestsā€).
  1. Auto-Approved Chores
  • Request: Add an option to automatically approve certain chores. For example, chores like ā€œBrush your teethā€ could be trusted without requiring manual approval.
  1. Default Dashboard YAML
  • Request: Considering some of the required templating is a little more complex in these dashboards, it would be worth adding a ā€œDefaultā€ or ā€œInitialā€ dashboard configuration file to you this github project so there is a common place to maintain and update it.
  1. Time Sensitive or Critical Chores
  • Request: Mark key chores, such as feed the cat, with an attribute to identify it as a time sensitive chore that you could easily filter for and build separate alerting or notifications if it is overdue.
Hi @ccpk1
Thanks for all the working you’ve put on this and all the comments. I was not able to test everything, cause I was focused on getting this out asap, so we would have something to play around and having more eyes finding issues. :slight_smile:
About the issues you’ve found and comments, let me try to clarify some of those. See my comments below.
That’s something I noticed, but I did not find a way yet to delete the entities. I am still learning also some programming and the inner works of HA. Let mee see if I find a way to handle this.
That’s also an issue that I found with my latest version. The problem was that before the date field was not populating from ConfigEntry, so every time you would go in it would be empty. As I mentioned on the GitHub discussions, that’s something that I need to rework almost entirely, also to give some meaning to the recurring frequency and dates.
That only happens with overdue chores I understand. Is that it?
So I though about that, but decided for leaving the Claim count intact, cause it would give an idea of how many times a chore has been claimed but not approved. If claim == approve, there was not so much meaning. So if claims > approved, you know the number of times a chore was claimed but not approved.
At least this made sense to me and my use case.
Well, that was by design, but makes sense to sum to the points_earned. Let me revisit that.
That should not happen. In my tests that was working properly and time dependent. I will need to recheck that.
  1. That’s something already on my roadmap to review.
  2. Kid State vs Global State. This one is a bit trickier. The main idea is that s shared chore may be Globally approved, because one kid successfully accomplished the chore, but another kid may not participate on that task (or may not perform it well). This means that the chore is approved, the chore on kid 1 will be shown as approved, but for Kid 2 it will be shown as pending. Hope this clarifies the question.
  3. Shared chores. Noted to include this on a FAQ. But in summary, yes, each chore shall be assigned to the kids you want. If not assigned the kids cannot claim the chores.
Let me try to break this down:
  1. You don’t need to set a due date for each chore, actually you can leave the due date empty and it will not affect. The same for recurring frequency, which may also be set as None. I will expand the ā€œmandatoryā€ fields check during setup (which some are already set), but as I see it, right now, you can do this without an issue.
  2. I believe that this would change a bit the whole concept. Maybe you can add some automation for this and use the ā€œapprove_choreā€ service to automatically approve those chores at the time you may specify. That’s the best solution I can think of without complicating to much the whole mechanic of the integration.
  3. Integrations cannot incorporate Lovelace cards. In the future I may considering developing a separate integration only with lovelace cards, but by the moment I will stick to the base of the integration and maybe move from there in the future once this is stable.
Hope this all helps. I will get a copy of your post and get it on the Github to ease my follow-up.
Cheers
Thank you for the detailed response. There are a couple of things I’m seeing work differently than you describe, so for the issues, I’ll log an issue for each one I’m still seeing so I can provide some more detail and specifics. I’ll do the same for Feature request, but of course those are lower priority.
Thanks again!
In case anyone is interested, here is a quick card to show outstanding approvals.
type: grid
square: false
columns: 1
cards:
  - type: heading
    heading: PARENT Required Actions
    primary: |
      {{ states('sensor.pending_reward_approvals') | title }} Approvals
    icon: mdi:gift-open-outline
    multiline_secondary: true
    secondary: >
      {% for kid, rewards in
      states.sensor.pending_reward_approvals.attributes.items() if kid not in
      ['icon', 'friendly_name'] -%}
        {{ kid }}:
        {% for reward in rewards -%}
          {{ reward.reward_name }} (Claimed on: {{ reward['Redeemed on'] | as_timestamp | timestamp_custom('%Y-%m-%d %H:%M', true) }})
        {% endfor %}
      {% endfor %}
    primary: |
      {{ states('sensor.pending_chore_approvals') | title }} Approvals
    icon: mdi:clipboard-check-outline
    secondary: >
      {% for kid, chores in
      states.sensor.pending_chore_approvals.attributes.items() if kid not in
        {{ kid }}:
        {% for chore in chores -%}
          {{ chore.chore_name }} (Claimed on: {{ chore['Claimed on'] | as_timestamp | timestamp_custom('%Y-%m-%d %H:%M', true) }})
        {% endfor %}
      {% endfor %}
Hi everyone,
I just released version 0.1.2-beta-rc3.
Here is the actual changelog:
What’s New
  • Remove BinarySensors platform.
    these were currently redundant and deemed unnecessary
  • Fix Kids ability to claim chores and rewards (closes #12)
  • Fix chore disapprovals not cleaning Kid’s Claimed Chores (closes #13)
  • Fix overdue chores not changing status to ā€œClaimedā€
  • Revise Recurring Frequency chores resets and handling
    • Chores without recurring frequency reset on a daily basis at midnight.
    • Chores with recurring frequency but no due date, reset on specific frequency (daily, weekly, monthly), based on creation date
    • Chores with recurring frequency and due date, reset on due date if approved and reschedule for next due date based on defined frequency.
    • Chores with recurring frequency and due date that are overdue, reschedule immediately to the next applicable due date in the future, upon Approval, and get status reset to Pending.
Let me know if there is any issue with these changes. Once I can, I will get back to this and work on the other things that are still outstanding.
Cheers
HI everyone,
I just released version 0.1.3-beta-rc4.
Here is the changelog:
What’s Changed
  • Fix addressing blank date in chore creation as well as properly bring… by @ccpk1 in Fix addressing blank date in chore creation as well as properly bring… by ccpk1 Ā· Pull Request #17 Ā· ad-ha/kidschores-ha Ā· GitHub
  • Complete revision, refactor and clean up Coordinator. Breakdown functions and code reorganization.
  • Revise mechanics to reset chores (daily/weekly/monthly) and due date recalculation
  • Revise due date recalculation for chores with recurring frequency and no due date.
    assign hidden date to set creation date and time 23h59
  • Revise mechanics for Shared Chores sensor status.
    New status for only one kid claims/approves a chore:
    • Claimed (in-part)
    • Approved (in-part)
  • Created new Global State extra attribute on each Kid’s Chore Sensor to detail the global status. Each kid will see their status individually as Claimed/Approved for each chore.
  • Address the automatic deletion of entities on items removal from Configuration (chores, badges, penalties, etc…) (closes #15)
  • Revise ā€œOverdueā€ chores status being set before due time
  • Add persistent notifications for:
    • Claims/approvals/disapprovals for chores and rewards. For both parents and kids.
    • Badges awarding. For both parents and kids.
Hope nothing got broken on the way. From my testing it all goes as expected.
Excellent feedback and responses guys and nice work on the cards too, I’ve just added them so thanks.
Hi everyone,
Some progress updates on the integration with version 0.1.5-beta-rc5:
New Features
Achievements
  • Configurable from ConfigFlow and OptionsFlow
  • Users may setup achievements based on individual chores or global chores completion.
  • Tracks number of chores completed in a row for a given chore or global
  • Extra Reward Points can be awarded if kids reach the Achievement
Challenges
  • Similar to Achievements but with Start and End Date
  • Options vary from, as an example, ā€œComplete 60 chores in 1 monthā€ to ā€œComplete chores every day during 15 daysā€
Notifications
  • Implement HA companion actionable notifications
    • Approve/Disapprove or Remind Later actions on Chores/Rewards Claims
  • Add selectable options on ConfigFlow/OptionsFlow to define notification device for each parent/kid.
  • Activate or deactivate notifications (mobile or persistent) per parent/kid)
  • Revised notifications mechanism for each occurrence.
  • Revised mechanics so Overdue chore notification do not pop-up every 5 minutes.
  • Overdue Chores are notified once chore is overdue and once daily while overdue.
New Sensors
  • ChoreStatusSensor - shows the global state of shared chores
  • AchievementSensor (addresses #10)
  • ChallengeSensor
  • AchievementProgressSensor (addresses #10)
  • ChallengeProgressSensor
  • KidHighestStreakSensor (addresses #10)
  • ChoreStreakSensor (addresses #10)
Noteworthy Changes
  • Revise mechanics for Recurring Frequency Chores with Due Date.
    • Replace previous fixed weekly schedule, on Monday at 0h00, by dynamic daily checks.
    • Recurring chores are now reschedule everyday if status ā€œApprovedā€ or ā€œApproved (in-part)ā€ and due date in the past.
    • Chores are reschedule for next day, next week (same weekday) or next month.
    • Update entries on config_entry.option so rescheduled date is shown on OptionsFlow.
  • Ensure new data fields have safe fallback and get created if did not exist on previous versions (closes #20)
  • Fix datetime fields with HA dt_util. Existing data is automatically migrated to new format.
  • Migrate old datetime formats into UTC safe data
  • Revise translations to address new fields
  • Code cleanup and polishing of some functions
Stay tuned for more :rocket:
If everything goes smoothly, as I hope so, this integration might become public in a week. :+1:
Hey,
I just released version 0.1.6-beta-rc6, to solve some issues with the HA Companion Notifications, that were not being handled properly.
These are now showing properly and the actionable buttons are responding to the required functions.
If you run into an issue with anything on the integration, please let me know.
Cheers :beers:
Hi Everyone,
Now that the weekend is approaching, and it might be a nice weekend project, I’m thrilled to release KidsChores into public-preview :rocket:
You have all info on the first post of this topic.
IMPORTANT:
Hope you enjoy it.
Cheers :beers:
Hi, although I don’t use/need it: good job!
Maybe it might be better to avoid questions if you link to the installation instructions instead of the release code.
Thanks for the suggestion, @Nick4
The link for the main repository is on the initial post.
I know, but some people only look at the last posts in a thread.
Anyway, I just wanted to preserve you (or anyone else) from answering the obvious things.
Hi everyone,
I’m glad to come back, after some days, with a major update to the integration:
This one is packed with a lot of fixes and some interesting new features:
:rocket: What’s Changed
  • Revise overdue chore status after disapproval (closes #27)
  • Fix versioning in manifest.json (closes #28)
  • Fix issue with non-admin parents not being able to approve chores/rewards (closes #31)
  • Fix approval issue for chores associated with Achievements/Challenges (closes #32)
  • Fix fields not being populated with data while editing Achievements/Challenges (closes #33)
  • Fix Achievements/Challenges sensors being created for all kids, even if kids were not assigned (closes #34)
  • Fix Chore sensors being created for kids that are not assigned (closes #38)
  • Fix HA User and Notification Service fields not being populated while editing Kids and Parents (closes #39)
  • Fix reset of chores with recurring frequency set to none that were skipped (closes #40)
:family: New Features
  • Add ability to select specific applicable days for chores (closes #26)
  • Allow notifications to be granularly defined by chore (claim, approval, disapproval) (closes #29)
  • Standardize all entity names on initial integration setup (closes #37)
  • Add translation keys to all entities. Now all entities’ names, status and extra attributes are translatable via translation files.
  • Add Recurring Frequency, Assigned Kids, Chore Name and Description to Chore Sensors (individual and global) (closes #41)
  • Implement new Action/Service to Reset Overdue Chores, either globally, by chore and/or kid (closes #42)
  • Minor changes:
    • Revise Manual Points icons
    • Allow HA User and Notification Service fields to be empty during kids/parents setup
    • Revise datetime fields to be user time zone centered
    • Implement migration mechanisms for new features and fields
:tada: Lovelace Dashboard
Looking for a way to streamline your lovelace dashboard with this integration? Look no further and check the amazing post @ccpk1 prepared here: Auto Populating Dashboard for Kids Chores Ā· ad-ha/kidschores-ha Ā· Discussion #36 Ā· GitHub
:clap: Special Thanks
I would like to extend special thanks to @ccpk1 and @OptimusGREEN for their feedback/suggestions and help finding issues on the integration, which it being really helpful and making this move forward. Thank you :+1:
Buy Me A Coffee
Great work dude, some really good improvements there and thanks for the mention. If there’s anything else I can do to help, just reach out. I love this project already and my youngest has really engaged with it. Superb.
Where was this 4months ago LOL.
Ive built something similar manually.
took me quite a while as my kids are sneaky, toggeling chores on and off to accumilate points.
I added AM and PM times and on the dashboard it removes the chore buttons and adds a image stating its not chore time yet if it does not fall within the allowed AM or PM time frames, when their at school and so on.
also have diffrent chores for weekdays, weekends, and Holidays.
I going to spin up a new HA and give yours a go ,mine has alot of stuff going at the moment as I have 2 kids so dash is split in half on the tablet.
Still trying to find a way to add face or fingerprint to the dashboards so they cant fiddle with each others chores. its running on a old Samsung TabS2 and works really well.
integrated timers for TV when they redeem points, and Phone time, although google family link integration is still a uphill battle to get it to unlock a phone when HA triggers it, so I just have it send me a voice when one of them requests phone time then I unlock their phone.
Really love the idea, I’ve been building something similar using manually Entered helpers, But this is a super easy way to add chores and automatically display it on a dashboard.
I modified your dashboard, because it seems naming conventions changed a little bit. I’m running into an issue though. When setting up the dashboard chores that I have set on a weekly bases, I.E every week on Monday will still display Today.
Looking at the entities it created, I’m not seeing anywhere where the applicable days of the week are displayed. I see a due date entry, which automatically gets filled with today’s date if no date was entered. So, I’m at a lost on how to do this.
Also for chores both kids do over other day. boy loads dishwasher monday wednesday and friday, girl loads tuesday thursday and saturday. There’s no way to show that unless I create it as two seperate chores.
** Update - the auto populating dashboard now has it’s own thread, these older links in the message will eventually stop working: Introducing the KidsChores and Rewards Dashboard
Yes, I was in the same situation with various manual buttons and automations, but I have to say, this integration is really fantastic. You’re catching it while it’s being built, so there is a lot changing in the background as it’s only recently in preview. @VaReTaS has a very large list of improvements and bug fixes that will go in very soon.
In the meantime, if you’re just starting out with 0.1.8, use the newest version of the auto populating dashboard I just posted after that release. Note if you started before 0.1.8, I’d recommend removing and starting again as noted in the first post. Most up to date dashboard is in post #36 for now. Auto Populating Dashboard for Kids Chores (Legacy Beta Users) Ā· ad-ha/kidschores-ha Ā· Discussion #36 Ā· GitHub
One other thing. I haven’t fully tested the recurrence with applicable days yet, but I can tell there is currently a bug that causes newly created chores not to get the scheduling updates they should have until after they go through 1 approval process which means they are approved, then after midnight of their original due date. At that time, they will be reset to pending status, and the attribute in the chore sensor named ā€œdue_dateā€ will be updated to the next scheduled time. Again, most of these issues are actually fixed, I believe he’s just ironing out a few more open items to do the next release.
