(AI assisted)
Guide: Killing the Matter Pairing Loop (SwitchBot Garage & Other Stubborn Devices)
SwitchBot Garage Door Opener, B0F21TFB4C, W5502330
The Issue: The “Matter Purgatory” Cycle
We’ve all been there: You bought a shiny new SwitchBot Garage Dongle. You follow the “easy” instructions, scan the QR code in Apple Home or the SwitchBot app, and try to “Share” it with Home Assistant.
The result? A 44-second wait followed by the digital equivalent of a blank stare: Failed to connect on any discovered server or Timed out during Attestation. Your logs look like a conversation between two people who speak different dialects of “Failure.” You reboot your Apple TV, you dance with your phone, and you consider whether the device would look better at the bottom of a lake.
The Real Problem: Most of these failures happen during the “Multi-Admin” handshake. The device is trying to talk to Apple Home AND Home Assistant at the same time, and the tiny chip inside the dongle has a cryptographic panic attack.
The Fix: The “Direct Boss” Protocol
We are going to stop asking Apple or the SwitchBot app for permission. We are going to make Home Assistant the Primary Controller by pre-loading Wi-Fi credentials and commissioning the device directly.
Step 1: Tell HA the Wi-Fi Secrets
Before you even touch the hardware, Home Assistant needs to know which Wi-Fi network to “gift” to the device.
- In Home Assistant, go to Settings > Matter.
- Scroll to the bottom to find Developer Tools.
- Select “Set Wi-Fi Credentials”.
- Enter your SSID and Password. (HA now holds these ready like a professional valet waiting to park your garage opener).
Step 2: The Hard Reset (The Exorcism)
The dongle is currently haunted by failed pairing attempts. We must clear its soul.
- Find the button on the back of the SwitchBot Garage Dongle.
- Hold it down for +10 seconds.
- The LED should flash, indicating it has forgotten its failed relationship with Apple. It is now in a clean “Pairing Mode.”
Step 3: The Mobile Handshake
- Open the Home Assistant Companion App on your phone.
- Go to Settings > Matter.
- Scroll to the bottom and select Developer Tools.
- Select “Commission device with mobile app”.
- Scan the QR code on the physical dongle.
Why this works: Your phone uses Bluetooth to talk to the dongle, tells it “Here is the Wi-Fi info HA gave me,” and the dongle joins your network and HA’s Matter Fabric directly. No Apple TV, no SwitchBot cloud, no middleman. Just pure, local control.
Still stuck? Ask an AI
If you are still staring at logs that look like the scrolling green text from The Matrix, copy them and feed them to an AI with this specific prompt:
"I am troubleshooting a Matter device pairing issue in Home Assistant. I have already tried a factory reset and the ‘Set Wi-Fi Credentials’ developer tool bypass. Despite this, the commissioning is still failing.
Below are my recent logs from the Matter Server. Please analyze these logs specifically for:
- The exact phase where the handshake fails (e.g., PASE, CASE, or Attestation).
- Any mDNS discovery errors or IPv6 routing issues (look for
_matter._tcp.localfailures).- Suggestions for specific network settings (like IGMP Snooping, IPv6 subnets, or mDNS reflection) that might be blocking the ‘Commissioning Complete’ signal.
[PASTE YOUR LOGS HERE]"
