KinCony KC868-AG Custom Firmware & HACS Integration
Hi everyone! ![]()
We have been working on a new custom firmware and HACS integration for the KinCony KC868-AG hub. Made this to work with Haptique RS90 universal remote which we make and sell. It is made open for the community.
If you own this device, you know itโs great hardware, but configuring it via standard ESPHome or MQTT can sometimes be tedious if you have a lot of remotes. We wanted to build a solution that makes capturing Infrared (IR) and RF 433MHz signals effortless.
Why use this over ESPHome or Broadlink?
- Local Storage: Capture and store commands directly on the device memory.
- Low Code: No need to write complex YAML configurations for every single button press.
- Ready-to-use Cards: The integration provides the necessary entities and UI in Home Assistant.
- Unified Hub: Handles both IR and RF433 in one local interface.
Download & Install
1. The Firmware
Flash your device with our custom firmware to enable local storage and API features.
Get the Firmware here
2. The Home Assistant Integration
Install via HACS (Custom Repository) to connect the hub to your HA instance.
Get the HACS Integration here
Quick Start
- Flash the firmware to your KC868-AG.
- Add the repo to HACS and install the integration.
- Go to the integration page.
- The command is saved locally and instantly available in HA!
Let us know what you think or if you run into any issues! ![]()
