Kindly assist with the following yaml code
kindly assist i keep on getting an error in the following line when compiling: return id(lawn_sprinkler_ctrlr)->valve[0]->run_time_remaining() / 60.0f
Blockquote
esphome:
friendly_name: Irrigation
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “8utVPTBUl/Wdj1toKLosz7lgyabFU2iN5i/y8k4rPwM=”
ota:
  • platform: esphome
    password: “6981dbc0a22c860bede34a9b567225f5”
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.8.111
gateway: 192.168.8.1
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Irrigation Fallback Hotspot”
password: “APOsweW0dgfS”
captive_portal:
binary_sensor:
  • platform: status
    name: “Irrigation Controller Status”
sprinkler:
  • id: lawn_sprinkler_ctrlr
    main_switch: “Sprinklers”
    auto_advance_switch: “Sprinklers Auto Advance”
    reverse_switch: “Sprinklers Reverse”
    multiplier_number: “Sprinkler Multiplier”
    repeat_number: “Sprinkler Repeat”
    valve_overlap: 5s
    valves:
    • valve_switch: “Zone 1”
      enable_switch: “Enable Zone 1”
      run_duration_number: “Zone 1 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw0
    • valve_switch: “Zone 2”
      enable_switch: “Enable Zone 2”
      run_duration_number: “Zone 2 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw1
    • valve_switch: “Zone 3”
      enable_switch: “Enable Zone 3”
      run_duration_number: “Zone 3 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw2
    • valve_switch: “Zone 4”
      enable_switch: “Enable Zone 4”
      run_duration_number: “Zone 4 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw3
    • valve_switch: “Zone 5”
      enable_switch: “Enable Zone 5”
      run_duration_number: “Zone 5 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw4
    • valve_switch: “Zone 6”
      enable_switch: “Enable Zone 6”
      run_duration_number: “Zone 6 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw5
    • valve_switch: “Zone 7”
      enable_switch: “Enable Zone 7”
      run_duration_number: “Zone 7 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw6
    • valve_switch: “Zone 8”
      enable_switch: “Enable Zone 8”
      run_duration_number: “Zone 8 Run Duration”
      valve_switch_id: lawn_sprinkler_valve_sw7
switch:
  • platform: gpio
    pin: GPIO03
    inverted: True
  • platform: gpio
    pin: GPIO13
    inverted: True
  • platform: gpio
    pin: GPIO14
    inverted: true
  • platform: gpio
    pin: GPIO04
    inverted: true
  • platform: gpio
    pin: GPIO05
    inverted: true
  • platform: gpio
    pin: GPIO16
    inverted: true
  • platform: gpio
    pin: GPIO25
    inverted: true
  • platform: gpio
    pin: GPIO26
    inverted: true
TIME REMAINING SENSORS
(Updated from HA)
  • platform: template
    name: “Zone 1 Time Remaining”
    unit_of_measurement: “min”
    accuracy_decimals: 1
    icon: “mdi:timer-sand”
    lambda: |-
    // Access the valve directly from the sprinkler controller’s valves array
    // Zone 1 corresponds to index
    return id(lawn_sprinkler_ctrlr)->valve[0]->run_time_remaining() / 60.0f;
    update_interval: 1s
    name: “Zone 2 Time Remaining”
    accuracy_decimals: 0
    name: “Zone 3 Time Remaining”
    name: “Zone 4 Time Remaining”
    name: “Zone 5 Time Remaining”
    name: “Zone 6 Time Remaining”
    name: “Zone 7 Time Remaining”
    name: “Zone 8 Time Remaining”
Blockquote
Where did you get this yaml code from? Did this come from AI/LLM, as the spacing is not in yaml format, or has the forum software munged your quoting when you used the </>?
yes somehow the spacing got changed i copied it directly out of esphome editor in homeassistant
You are using “blockqoute”, you want to use “preformatted text”
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "8utVPTBUl/Wdj1toKLosz7lgyabFU2iN5i/y8k4rPwM="
ota:
  - platform: esphome
    password: "6981dbc0a22c860bede34a9b567225f5"
wifi:
  manual_ip:
  ap:
    ssid: "Irrigation Fallback Hotspot"
    password: "APOsweW0dgfS"
captive_portal:
binary_sensor:
  - platform: status
    name: "Irrigation Controller Status"
sprinkler:
  - id: lawn_sprinkler_ctrlr
    main_switch: "Sprinklers"
    auto_advance_switch: "Sprinklers Auto Advance"
    reverse_switch: "Sprinklers Reverse"
    multiplier_number: "Sprinkler Multiplier"
    repeat_number: "Sprinkler Repeat"
    valve_overlap: 5s
    valves:
      - valve_switch: "Zone 1"
        enable_switch: "Enable Zone 1"
        run_duration_number: "Zone 1 Run Duration"
      - valve_switch: "Zone 2"
        enable_switch: "Enable Zone 2"
        run_duration_number: "Zone 2 Run Duration"
      - valve_switch: "Zone 3"
        enable_switch: "Enable Zone 3"
        run_duration_number: "Zone 3 Run Duration"
      - valve_switch: "Zone 4"
        enable_switch: "Enable Zone 4"
        run_duration_number: "Zone 4 Run Duration"
      - valve_switch: "Zone 5"
        enable_switch: "Enable Zone 5"
        run_duration_number: "Zone 5 Run Duration"
      - valve_switch: "Zone 6"
        enable_switch: "Enable Zone 6"
        run_duration_number: "Zone 6 Run Duration"
      - valve_switch: "Zone 7"
        enable_switch: "Enable Zone 7"
        run_duration_number: "Zone 7 Run Duration"
      - valve_switch: "Zone 8"
        enable_switch: "Enable Zone 8"
        run_duration_number: "Zone 8 Run Duration"
switch:
  - platform: gpio
    pin: GPIO03
    inverted: True
  - platform: gpio
    pin: GPIO13
    inverted: True
  - platform: gpio
    pin: GPIO14
    inverted: true
  - platform: gpio
    pin: GPIO04
    inverted: true
  - platform: gpio
    pin: GPIO05
    inverted: true
  - platform: gpio
    pin: GPIO16
    inverted: true
  - platform: gpio
    pin: GPIO25
    inverted: true
  - platform: gpio
    pin: GPIO26
    inverted: true
# TIME REMAINING SENSORS
# (Updated from HA)
    name: "Zone 1 Time Remaining"
    unit_of_measurement: "min"
    icon: mdi:timer-sand
    update_interval: 1s
    lambda: |-
      // Safety check: make sure valve exists and is running
      if (id(lawn_sprinkler_ctrlr).valves_.size() == 0 ||
          !id(lawn_sprinkler_ctrlr).valves_[0].is_running()) {
        return 0.0f;
      // Remaining duration is returned in seconds
               .valves_[0]
               .get_remaining_duration() / 60.0f;
    name: "Zone 2 Time Remaining"
    name: "Zone 3 Time Remaining"
    name: "Zone 4 Time Remaining"
    name: "Zone 5 Time Remaining"
    name: "Zone 6 Time Remaining"
    name: "Zone 7 Time Remaining"
    name: "Zone 8 Time Remaining"
I tried another way but i also cant get this to work/compile
Is this generated by AI?
According to the ESPHome API, the proper way to get the list of valves is id(lawn_sprinkler_ctrlr).valve_
https://api-docs.esphome.io/classesphome_1_1sprinkler_1_1_sprinkler#a1070ffeb9226dc080bdf74792c94724a
Anyway, if you want more help, please specify the actual error you’re getting.
.time_remaining_active_valve()
Have a look at the example on docs:
    display:
      - platform: ...
        # ...display configuration...
        lambda: |-
          if (id(lawn_sprinkler_ctrlr).time_remaining_active_valve().has_value()) {
            // the controller is running, print the number of seconds remaining
            it.printf(0, 0, "Time left: %u sec.", id(lawn_sprinkler_ctrlr).time_remaining_active_valve().value());
          } else {
            // the controller is NOT running
            it.print(0, 0, "Idle");
Please i need help to display the “zone time remaining” per zone…any solution will help to so…i have tried a lot of options but cant get it working.
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
ota:
  - platform: esphome
wifi:
  manual_ip:
  ap:
captive_portal:
sprinkler:
    valve_overlap: 5s
    valves:
switch:
  - platform: gpio
    pin: GPIO03
    inverted: True
  - platform: gpio
    pin: GPIO13
    inverted: True
  - platform: gpio
    pin: GPIO14
    inverted: true
  - platform: gpio
    pin: GPIO04
    inverted: true
  - platform: gpio
    pin: GPIO05
    inverted: true
  - platform: gpio
    pin: GPIO16
    inverted: true
  - platform: gpio
    pin: GPIO25
    inverted: true
  - platform: gpio
    pin: GPIO26
    inverted: true
this is my working code so far. I cant get the time remainingg to work.
I have added the following code. The entities work but it does not display the time.
I am new to home-assistant. I do not know how to interpret this link you send me?
Try like this (state 2 is active):
    unit_of_measurement: "s"
    update_interval: 1s
    lambda: |-
      auto v = id(lawn_sprinkler_ctrlr)->valve(1);
      if (v->state() == 2) {
        return v->time_remaining();
      return 0;
Many thanks for the help. I will action on Monday i am away from home at the moment.
