Kiosk , added via HACS, not working
Hi All
I am having some trouble with configuring Kiosk
I installed Kiosk via HACS and added
resources:
  - url: /hacsfiles/kiosk-mode/kiosk-mode.js
    type: module
in configuration.yaml file as per instructions, but getting following error in a log after reboot
2024-03-21 20:07:36.617 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-21 20:07:48.026 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘resources’: Integration not found.
Any idea how to sort it?
