I have a Flow that turns on my kitchen lights with motion (if no movie is playing), but enables a hue lab for the under cabinet light.
Now I am sure it is something silly, but when I run the flow in real life the lights under the cabinet turn on for 2 seconds, then off. This is inexplicable because I see nothing that would cause this result.
The same happens at night. Here is the flow:
[{"id":"3085833c.87392c","type":"group","z":"89a554b6.4b0b28","name":"","style":{"label":true},"nodes":["85397004.d372e8","bfff1866.41299","89e891e3.09d2c","229ca71b.dee748","393d622a.bd7f06","2896650f.ba556a","44cc327d.6231cc","be69a557.5de24","d97bfcb5.aee408","37431788.b822c8","292ca855.cbf2f8","59f2d379.1117f4","795c65fe.418e14","9854879a.d2885","1b1213fa.216a4c","b1a44b74.9d2c9","3a1baf7a.fd4d","2f9f7e6c.bdb242","92b2160a.b46f2","acaf4daa.fb0ff8","a2b00048.bf73b"],"x":14,"y":679,"w":1532,"h":422},{"id":"85397004.d372e8","type":"server-state-changed","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Motion","server":"8efa78ba.f10338","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.kitchen_motion_sensor_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":900,"wires":[["59f2d379.1117f4","3a1baf7a.fd4d"],["89e891e3.09d2c"]]},{"id":"bfff1866.41299","type":"api-current-state","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Mode","server":"8efa78ba.f10338","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.ha_modes","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":550,"y":860,"wires":[["229ca71b.dee748"]]},{"id":"89e891e3.09d2c","type":"api-current-state","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Mode","server":"8efa78ba.f10338","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.ha_modes","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":370,"y":980,"wires":[["393d622a.bd7f06"]]},{"id":"229ca71b.dee748","type":"switch","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Day","vt":"str"},{"t":"eq","v":"Guest","vt":"str"},{"t":"eq","v":"Night","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":690,"y":840,"wires":[["2896650f.ba556a","be69a557.5de24","795c65fe.418e14"],["2896650f.ba556a","be69a557.5de24","795c65fe.418e14"],["37431788.b822c8"]]},{"id":"393d622a.bd7f06","type":"switch","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Day","vt":"str"},{"t":"eq","v":"Guest","vt":"str"},{"t":"eq","v":"Night","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":690,"y":980,"wires":[["1b1213fa.216a4c"],["1b1213fa.216a4c"],["b1a44b74.9d2c9"]]},{"id":"2896650f.ba556a","type":"api-call-service","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Lights On","server":"8efa78ba.f10338","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.kitchen_island_lights, light.kitchen_main_overhead_lights","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1060,"y":780,"wires":[[]]},{"id":"44cc327d.6231cc","type":"http request","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.7.14/api/yWt3xqiNauS0iLVV9xkQg-uK12BR8tdBwOQAuvtn/sensors/23/state/1","tls":"","persist":false,"proxy":"","authType":"","x":1270,"y":820,"wires":[[]]},{"id":"be69a557.5de24","type":"change","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Hue Day Scene","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":1}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":820,"wires":[["44cc327d.6231cc"]]},{"id":"d97bfcb5.aee408","type":"http request","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.7.14/api/yWt3xqiNauS0iLVV9xkQg-uK12BR8tdBwOQAuvtn/sensors/28/state/1","tls":"","persist":false,"proxy":"","authType":"","x":1290,"y":860,"wires":[[]]},{"id":"37431788.b822c8","type":"change","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Hue Night Scene","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":1}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":860,"wires":[["d97bfcb5.aee408"]]},{"id":"292ca855.cbf2f8","type":"api-call-service","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Lights Off","server":"8efa78ba.f10338","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.kitchen_island_lights, light.kitchen_main_overhead_lights, light.kitchen_single_bulb, light.kitchen_strip_1, light.kitchen_strip_2, light.kitchen_strip_3, light.kitchen_strip_4","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1460,"y":940,"wires":[[]]},{"id":"59f2d379.1117f4","type":"api-current-state","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Popcorn?","server":"8efa78ba.f10338","version":2,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.popcorn","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":380,"y":860,"wires":[["bfff1866.41299"],[]]},{"id":"795c65fe.418e14","type":"time-range-switch","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Dinner Time","lat":"","lon":"","startTime":"17:00","endTime":"20:30","startOffset":0,"endOffset":0,"x":1070,"y":740,"wires":[["9854879a.d2885"],[]]},{"id":"9854879a.d2885","type":"api-call-service","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Kitchen Table","server":"8efa78ba.f10338","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.dining_room_light","data":"{\"brightness\":100,\"transition\":10}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1260,"y":720,"wires":[[]]},{"id":"1b1213fa.216a4c","type":"trigger","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"10","extend":true,"overrideDelay":false,"units":"min","reset":"on","bytopic":"all","topic":"topic","outputs":1,"x":910,"y":940,"wires":[["a2b00048.bf73b"]]},{"id":"b1a44b74.9d2c9","type":"trigger","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"2","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":910,"y":1060,"wires":[["92b2160a.b46f2"]]},{"id":"3a1baf7a.fd4d","type":"change","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":920,"wires":[["1b1213fa.216a4c","b1a44b74.9d2c9"]]},{"id":"2f9f7e6c.bdb242","type":"comment","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Kitchen","info":"","x":90,"y":760,"wires":[]},{"id":"92b2160a.b46f2","type":"change","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Hue Night Scene","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":0}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":1040,"wires":[["75210172.df6c7"]]},{"id":"acaf4daa.fb0ff8","type":"http request","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.7.14/api/yWt3xqiNauS0iLVV9xkQg-uK12BR8tdBwOQAuvtn/sensors/23/state/","tls":"","persist":false,"proxy":"","authType":"","x":1250,"y":940,"wires":[["292ca855.cbf2f8"]]},{"id":"a2b00048.bf73b","type":"change","z":"89a554b6.4b0b28","g":"3085833c.87392c","name":"Hue Day Scene","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":0}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":940,"wires":[["acaf4daa.fb0ff8"]]},{"id":"8efa78ba.f10338","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Can anyone spot why the Hue Lab (the http get) would turn off?
