Kitchen Spotlights
I can see you can buy kitchen spotlights with Zigbee and Zwave. If you had say 8 spotlights, is this the best way to do it?
I wondered if there was such a Zigbee or Zwave device that you slaved cheaper bulbs from somehow, like a device with 8 light outputs you can adjust for brightness/colour?
I can see there are central controllers that control LED lighting strip, so I suppose I wondered if the same sort of thing applied to any other light/bulb types.
You can use 12V/24V LED spots that are equivalent to strip.
Something like these.
https://aliexpress.com/item/1005001873776089.html
For a kitchen, I’d just go with dumb lights & a smart switch (or dimmer). With Zwave & Zigbee, you’ll end up not being able to turn the lights off at the switch because you’ll kill the mesh.
I’m saying this because you will likely never need to switch on a single light - at a bare minimum you’d be switching 2 at a time.
You’ll also get tired pretty quickly of colour changing lights in a kitchen. Ask me how I know.
That just leaves you with brightness control, so you have 2 3 options:
  • Get a 2-3 gang smart switch and ask an electrician to split your lights into groups of 4-4 or 4-2-2.
  • Leave everything as a single group and get a single gang smart dimmer for general brightness control.
  • Combine both the above and get a 2 gang smart dimmer + split your lights into 2 groups. These are generally harder to find & depend on your country’s switch formats (which we don’t know yet), but they do exist.
But that takes out color control OP wanted.
My preference would be Shelly RGBW and dumb 12/24V RGBW spot lights. Equivalent to LED strip setup.
Smart lights losing power when used with a dumb mechanical switch can be solved with Shelly/Sonoff/Aqara devices that sit behind the switch and offer a decoupled mode.
