I got asked about how I did these kitchen timers in a different topic and that wasn’t a suitable place to explain it all and decided to create this to explain it all.
This thread was used as a source for creating the “dynamic timer”:
The card is a combination of a vertical stack with horizontal stack cards.
It uses the Button Card from RomRider and the Circular Timer Card for karlis-vagalis (you can find both in HACS)
Next to this you need to create an input_number for every timer and in my case 2 automations. The first automation starts the timer after adjusting the time, the second one resets the timer to the default time when it’s finished.
The Card:
type: vertical-stack
cards:
- type: custom:circular-timer-card
entity: timer.keukentimer_1
bins: 60
primary_info: none
empty_bar_color: "#e4d7fe"
color:
- "#4CAF50"
card_mod:
style: |
ha-card {
background: none;
border: none;
--ha-card-box-shadow: 0px;
- type: horizontal-stack
cards:
- type: custom:button-card
icon: mdi:stop-circle-outline
hold_action:
action: none
tap_action:
action: perform-action
perform_action: timer.cancel
entity_id: timer.keukentimer_1
data: {}
state:
- value: idle
color: "#4CAF50"
- value: active
color: "#4CAF50"
- value: paused
color: "#4CAF50"
show_state: false
show_name: false
styles:
icon:
- width: 70%
- transform: scale(1.1)
card_mod:
style: |
ha-card {
background: none;
border: none;
icon: mdi:play-circle-outline
hold_action:
action: none
tap_action:
perform_action: timer.start
data: {}
state:
- value: idle
color: "#4CAF50"
- value: active
color: "#4CAF50"
- value: paused
color: "#4CAF50"
show_state: false
show_name: false
styles:
icon:
- width: 70%
card_mod:
style: |
ha-card {
background: none;
border: none;
icon: mdi:pause-circle-outline
hold_action:
action: none
tap_action:
perform_action: timer.pause
data: {}
state:
- value: idle
color: "#4CAF50"
- value: active
color: "#4CAF50"
- value: paused
color: "#4CAF50"
show_state: false
show_name: false
styles:
icon:
- width: 70%
card_mod:
style: |
ha-card {
background: none;
border: none;
cards:
entity: input_number.keukentimer1
icon: mdi:minus-circle-outline
hold_action:
action: none
tap_action:
perform_action: input_number.decrement
entity_id: input_number.keukentimer1
show_state: false
show_name: false
styles:
icon:
- width: 50%
- color: "#4CAF50"
card_mod:
style: |
ha-card {
background: none;
border: none;
hold_action:
action: none
tap_action:
action: none
show_state: true
show_name: false
show_icon: false
styles:
card:
- font-size: 40px
- font-weight: bold
card_mod:
style: |
ha-card {
background: none;
border: none;
icon: mdi:plus-circle-outline
hold_action:
action: none
tap_action:
perform_action: input_number.increment
show_state: false
show_name: false
styles:
icon:
- width: 50%
- color: "#4CAF50"
card_mod:
style: |
ha-card {
background: none;
border: none;
grid_options:
columns: 12
rows: auto
Automation 1: Starts timer when adjusting the time.
triggers:
- entity_id: input_number.keukentimer1
trigger: state
conditions: []
actions:
- target:
duration: "{{ trigger.to_state.state | int(0) * 60 }}"
action: timer.start
Automation 2: Resets the timer to default value after finishing.
alias: Reset Keuken Timer 1 Input Number
description: ""
triggers:
- trigger: state
entity_id:
- timer.keukentimer_1
to: idle
for:
hours: 0
minutes: 0
seconds: 15
conditions: []
actions:
- action: automation.turn_off
metadata: {}
stop_actions: true
entity_id: automation.keuken_timer_1
- action: input_number.set_value
metadata: {}
value: 10
- action: automation.turn_on
metadata: {}
data: {}
mode: single
After reading it all back it probably can be done a bit easier and cleaner with the automations, but it works ![]()
