KNX button sending 1 on push and 0 on release
Hi, I’m new to HA but have experience with KNX and computer programming. I had no problem setting up light switches and dimmers but when it comes to buttons I got absolutely stuck. What I want is to send a 1 (one bit value) when a button is pressed and 0 when the button is released?
I’m a completely new to YAML and would really appreciate if someone could give me some example of how to achieve this.
Thank you!
Hi :wave:!
The default cards don’t support “release” actions. Maybe you can find custom cards that do.
Ok, would it be possible to achieve a “pulse” by sending 1 at key press and a second later send a 0?
Yes. That’s what scripts are for. It can probably also be done with a template button. Use knx.send and delay for that.
Ok, thanks a lot! Could you please give me a brief example of a script and how to call the script from a button press?
Thank you!
Maybe something like this, but how do I run the script from a button press?
script:
  automation:
    - name: auto
    - knx.send:
        address: "1/0/0"
        value: True
        type: "5.010"
      delay: 1
    - knx.send:
        address: "1/0/0"
        value: False
        type: "5.010"
Well, replace value with payload and maybe don’t use boolean as percent-payload. See https://www.home-assistant.io/integrations/knx/#send
I’m not sure how to call it. Last time I checked, it was just displayed like a button in the default dashboard, but that’s long time ago :upside_down_face:
Otherwise use a template button invoking the script or just calling this sequence.
Ok, I realise now you can run the script by itself from the dashboard. I tried the following but nothing showed up on the KNX bus when I run it from the script builder dialog!?
sequence:
  - knx.send:
      address: 1/0/0
      payload: 1
      payload_length: 1
    delay: 1
  - knx.send:
      address: 1/0/0
      payload: 0
      payload_length: 1
Please have a look at the documentation. https://www.home-assistant.io/docs/scripts/#call-a-service
and https://www.home-assistant.io/integrations/script/
You are missing service: knx.send and data:
Thank you for your reply!
Slowly getting there…
Tried this but nothing happens on the KNX bus?
  sequence:
    - service: knx.send
        address: 1/0/0
        payload: 1
        payload_length: 1
      delay: 1
    - service: knx.send
        address: 1/0/0
        payload: 0
        payload_length: 1
If you had a look at the logs, you’d probably see where the issue is.
delay can not be part of the knx.send service call, but is a separate item of the sequence.
Nothing is showing up in the logs!? Not even when I reduced the script to this:
  sequence:
    - service: knx.send
        address: 1/0/0
        payload: 1
this Script, done by the UI builder, yields the following yaml that works flawlessly on my system
alias: Test
sequence:
  - service: knx.send
      payload: 1
      address: 0/4/1
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - service: knx.send
      payload: 0
      address: 0/4/1
mode: single
go to Open your Home Assistant instance and show your scripts. to create a Script.
This is what mine look like. Still nothong on the bus when executed and nothing in logs. :worried:
You are firing an event, not calling a service. You picked the wrong action type.
Thank you so much!
Now I’m beginning to understand how things should be done. Now it’s working fine for me.
