I have a working KNX domotica system that works 100% with OpenRemote, so I am certain that there is nothing wrong with the basic KNX configuration.
I have tried to evaluate Home-Assistant on Raspberry Pi 3, using manual install on Jessie Lite.
If I have only one switch defined, it works.
Here is the switch definitions in config file:
knx:
host: 10.4.1.5
port: 3671
switch:
platform: knx
address: 1/1/1
state_address: 1/5/111
Here is the log file with one switch:
cat home-assistant.log
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=recorder>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=logger>
16-10-29 11:07:12 root: Started data server on UDP port 35982
16-10-29 11:07:12 root: Connected KNX IP tunnel (Channel: 122, HPAI: 8 1)
16-10-29 11:07:12 homeassistant.components.knx: Res = True
16-10-29 11:07:12 homeassistant.components.knx: KNX IP tunnel to 10.4.1.5:3671 established
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=knx>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=http>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=history>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=discovery>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=api>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=frontend>
16-10-29 11:07:12 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=updater>
16-10-29 11:07:12 homeassistant.loader: Loaded switch.knx from homeassistant.components.switch.knx
16-10-29 11:07:12 homeassistant.bootstrap: Component knx already set up.
16-10-29 11:07:12 homeassistant.components.knx: Initalizing KNX group address 2305
16-10-29 11:07:12 root: Received tunneling ACK
16-10-29 11:07:13 homeassistant.components.knx: Unable to read from KNX address: 2305 (None)
16-10-29 11:07:13 root: Got value of group address 3439 from cache: [0]
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state switch.entrance_hall=off; friendly_name=Entrance Hall @ 2016-10-29T11:07:13.870973+02:00>, old_state=None, entity_id=switch.entrance_hall>
16-10-29 11:07:13 homeassistant.loader: Loaded group from homeassistant.components.group
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; hidden=True, order=0, auto=True, entity_id=('switch.entrance_hall',), friendly_name=all switches @ 2016-10-29T11:07:13.877617+02:00>, old_state=None, entity_id=group.all_switches>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=toggle, domain=switch>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=switch>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=logbook>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=conversation>
16-10-29 11:07:13 homeassistant.core: Starting Home Assistant (11 threads)
16-10-29 11:07:13 homeassistant.core: Starting Home Assistant core loop
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event homeassistant_start[L]>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
16-10-29 11:07:13 homeassistant.core: Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
16-10-29 11:07:13 homeassistant.core: Timer:starting
16-10-29 11:07:14 netdisco.service: Scanning
16-10-29 11:07:30 root: Got value of group address 3439 from cache: [0]
16-10-29 11:08:00 root: Got value of group address 3439 from cache: [0]
16-10-29 11:08:23 root: Heartbeat: Send connection state request
16-10-29 11:08:23 root: Heartbeat: Successful
16-10-29 11:08:30 root: Got value of group address 3439 from cache: [0]
16-10-29 11:08:54 homeassistant.components.http: Serving / to 10.4.1.28 (auth: True)
16-10-29 11:08:55 homeassistant.components.http: Serving /api/bootstrap to 10.4.1.28 (auth: True)
16-10-29 11:08:55 homeassistant.components.http: Serving /api/stream to 10.4.1.28 (auth: True)
16-10-29 11:08:55 homeassistant.components.api: STREAM 1990442776 ATTACHED
16-10-29 11:08:55 homeassistant.components.api: STREAM 1990442776 WRITING data: ping
16-10-29 11:09:00 root: Got value of group address 3439 from cache: [0]
16-10-29 11:09:02 homeassistant.components.http: Serving /api/services/homeassistant/turn_on to 10.4.1.28 (auth: True)
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_on, service_data=entity_id=switch.entrance_hall, service_call_id=1977579888-1, domain=homeassistant>
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_on, service_data=entity_id=['switch.entrance_hall'], service_call_id=1977579888-2, domain=switch>
16-10-29 11:09:02 root: Received tunneling ACK
16-10-29 11:09:02 root: Got value of group address 3439 from cache: [0]
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1977579888-2>
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1977579888-1>
16-10-29 11:09:02 root: Got value of group address 3439 from cache: [1]
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state switch.entrance_hall=on; friendly_name=Entrance Hall @ 2016-10-29T11:09:02.601299+02:00>, old_state=<state switch.entrance_hall=off; friendly_name=Entrance Hall @ 2016-10-29T11:07:13.870973+02:00>, entity_id=switch.entrance_hall>
16-10-29 11:09:02 homeassistant.components.api: STREAM 1990442776 FORWARDING <Event state_changed[L]: new_state=<state switch.entrance_hall=on; friendly_name=Entrance Hall @ 2016-10-29T11:09:02.601299+02:00>, old_state=<state switch.entrance_hall=off; friendly_name=Entrance Hall @ 2016-10-29T11:07:13.870973+02:00>, entity_id=switch.entrance_hall>
16-10-29 11:09:02 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=on; hidden=True, order=0, auto=True, entity_id=('switch.entrance_hall',), friendly_name=all switches @ 2016-10-29T11:09:02.610225+02:00>, old_state=<state group.all_switches=off; hidden=True, order=0, auto=True, entity_id=('switch.entrance_hall',), friendly_name=all switches @ 2016-10-29T11:07:13.877617+02:00>, entity_id=group.all_switches>
16-10-29 11:09:02 homeassistant.components.api: STREAM 1990442776 WRITING data: {"data": {"new_state": {"last_updated": "2016-10-29T09:09:02.601299+00:00", "attributes": {"friendly_name": "Entrance Hall"}, "state": "on", "last_changed": "2016-10-29T09:09:02.601299+00:00", "entity_id": "switch.entrance_hall"}, "old_state": {"last_updated": "2016-10-29T09:07:13.870973+00:00", "attributes": {"friendly_name": "Entrance Hall"}, "state": "off", "last_changed": "2016-10-29T09:07:13.870973+00:00", "entity_id": "switch.entrance_hall"}, "entity_id": "switch.entrance_hall"}, "time_fired": "2016-10-29T09:09:02.601537+00:00", "event_type": "state_changed", "origin": "LOCAL"}
16-10-29 11:09:02 homeassistant.components.api: STREAM 1990442776 FORWARDING <Event state_changed[L]: new_state=<state group.all_switches=on; hidden=True, order=0, auto=True, entity_id=('switch.entrance_hall',), friendly_name=all switches @ 2016-10-29T11:09:02.610225+02:00>, old_state=<state group.all_switches=off; hidden=True, order=0, auto=True, entity_id=('switch.entrance_hall',), friendly_name=all switches @ 2016-10-29T11:07:13.877617+02:00>, entity_id=group.all_switches>
16-10-29 11:09:02 homeassistant.components.api: STREAM 1990442776 WRITING data: {"data": {"new_state": {"last_updated": "2016-10-29T09:09:02.610225+00:00", "attributes": {"hidden": true, "order": 0, "auto": true, "entity_id": ["switch.entrance_hall"], "friendly_name": "all switches"}, "state": "on", "last_changed": "2016-10-29T09:09:02.610225+00:00", "entity_id": "group.all_switches"}, "old_state": {"last_updated": "2016-10-29T09:07:13.877617+00:00", "attributes": {"hidden": true, "order": 0, "auto": true, "entity_id": ["switch.entrance_hall"], "friendly_name": "all switches"}, "state": "off", "last_changed": "2016-10-29T09:07:13.877617+00:00", "entity_id": "group.all_switches"}, "entity_id": "group.all_switches"}, "time_fired": "2016-10-29T09:09:02.610410+00:00", "event_type": "state_changed", "origin": "LOCAL"}
16-10-29 11:09:23 root: Heartbeat: Send connection state request
16-10-29 11:09:23 root: Heartbeat: Successful
16-10-29 11:09:30 root: Got value of group address 3439 from cache: [1]
If I define two switches, there is a problem.
Configuration file for two switches:
knx:
host: 10.4.1.5
port: 3671
switch toilet:
platform: knx
address: 1/1/3
state_address: 1/5/110
switch hall:
platform: knx
address: 1/1/1
Log file for two switches:
16-10-29 11:12:00 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=recorder>
16-10-29 11:12:00 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=logger>
16-10-29 11:12:00 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=updater>
16-10-29 11:12:01 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=http>
16-10-29 11:12:01 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=conversation>
16-10-29 11:12:02 root: Started data server on UDP port 39416
16-10-29 11:12:02 root: Connected KNX IP tunnel (Channel: 123, HPAI: 8 1)
16-10-29 11:12:02 homeassistant.components.knx: Res = True
16-10-29 11:12:02 homeassistant.components.knx: KNX IP tunnel to 10.4.1.5:3671 established
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=knx>
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=api>
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=frontend>
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
16-10-29 11:12:02 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=logbook>
16-10-29 11:12:02 homeassistant.loader: Loaded switch.knx from homeassistant.components.switch.knx
16-10-29 11:12:02 homeassistant.bootstrap: Component knx already set up.
16-10-29 11:12:02 homeassistant.components.knx: Initalizing KNX group address 2305
16-10-29 11:12:02 homeassistant.components.knx: Initalizing KNX group address 2307
16-10-29 11:12:02 root: Received tunneling ACK
16-10-29 11:12:03 homeassistant.components.knx: Unable to read from KNX address: 2305 (None)
16-10-29 11:12:03 root: Got value of group address 3439 from cache: [1]
16-10-29 11:12:03 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.entrance_hall, new_state=<state switch.entrance_hall=on; friendly_name=Entrance Hall @ 2016-10-29T11:12:03.383047+02:00>>
16-10-29 11:12:03 homeassistant.loader: Loaded group from homeassistant.components.group
16-10-29 11:12:03 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.all_switches, new_state=<state group.all_switches=on; auto=True, order=0, entity_id=('switch.entrance_hall',), hidden=True, friendly_name=all switches @ 2016-10-29T11:12:03.389861+02:00>>
16-10-29 11:12:03 root: Received tunneling ACK
16-10-29 11:12:04 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:12:04 root: Received tunneling ACK
16-10-29 11:12:16 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.guest_toilet, new_state=<state switch.guest_toilet=off; friendly_name=Guest Toilet @ 2016-10-29T11:12:16.742816+02:00>>
16-10-29 11:12:16 root: Got value of group address 3439 from cache: [1]
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=<state group.all_switches=on; auto=True, order=0, entity_id=('switch.entrance_hall',), hidden=True, friendly_name=all switches @ 2016-10-29T11:12:03.389861+02:00>, entity_id=group.all_switches, new_state=None>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.all_switches, new_state=<state group.all_switches=on; auto=True, order=0, entity_id=('switch.entrance_hall', 'switch.guest_toilet'), hidden=True, friendly_name=all switches @ 2016-10-29T11:12:16.751034+02:00>>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=switch, service=toggle>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=switch>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=history>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=discovery>
16-10-29 11:12:16 homeassistant.core: Starting Home Assistant (11 threads)
16-10-29 11:12:16 homeassistant.core: Starting Home Assistant core loop
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event homeassistant_start[L]>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
16-10-29 11:12:16 homeassistant.core: Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
16-10-29 11:12:16 homeassistant.core: Timer:starting
16-10-29 11:12:17 netdisco.service: Scanning
16-10-29 11:12:30 root: Got value of group address 3439 from cache: [1]
16-10-29 11:12:32 homeassistant.components.http: Serving /api/stream to 10.4.1.28 (auth: True)
16-10-29 11:12:32 homeassistant.components.api: STREAM 1991089944 ATTACHED
16-10-29 11:12:32 homeassistant.components.api: STREAM 1991089944 WRITING data: ping
16-10-29 11:12:32 homeassistant.components.http: Serving /api/bootstrap to 10.4.1.28 (auth: True)
16-10-29 11:12:32 root: Disconnecting KNX/IP tunnel...
16-10-29 11:12:32 root: Data server already running, not starting again
16-10-29 11:12:32 root: Connected KNX IP tunnel (Channel: 124, HPAI: 8 1)
16-10-29 11:12:33 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:12:35 root: Disconnecting KNX/IP tunnel...
16-10-29 11:12:35 root: Data server already running, not starting again
16-10-29 11:12:35 root: Connected KNX IP tunnel (Channel: 125, HPAI: 8 1)
16-10-29 11:12:36 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:12:38 root: Disconnecting KNX/IP tunnel...
16-10-29 11:12:38 root: Data server already running, not starting again
16-10-29 11:12:38 root: Connected KNX IP tunnel (Channel: 126, HPAI: 8 1)
16-10-29 11:12:39 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:13:02 root: Disconnecting KNX/IP tunnel...
16-10-29 11:13:02 root: Data server already running, not starting again
16-10-29 11:13:02 root: Connected KNX IP tunnel (Channel: 128, HPAI: 8 1)
16-10-29 11:13:03 homeassistant.components.knx: Unable to read from KNX address: 2305 (None)
16-10-29 11:13:04 root: KNX/IP gateway did not respond to connect request
16-10-29 11:13:05 homeassistant.components.knx: Unable to read from KNX address: 2307 (None)
16-10-29 11:13:05 root: Disconnecting KNX/IP tunnel...
16-10-29 11:13:05 homeassistant.core: Error inside async loop: Task exception was never retrieved
16-10-29 11:13:05 homeassistant.core: Exception inside async loop:
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 210, in async_update_ha_state
state = STATE_UNKNOWN if self.state is None else str(self.state)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 298, in state
return STATE_ON if self.is_on else STATE_OFF
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/knx.py", line 165, in is_on
self.update()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/knx.py", line 194, in update
self.state_address, use_cache=self.cache)
File "/home/pi/.homeassistant/deps/knxip/ip.py", line 557, in group_read
self.send_tunnelling_request(cemi)
File "/home/pi/.homeassistant/deps/knxip/ip.py", line 539, in send_tunnelling_request
self.disconnect()
File "/home/pi/.homeassistant/deps/knxip/ip.py", line 387, in disconnect
frame.body = self.hpai_body()
File "/home/pi/.homeassistant/deps/knxip/ip.py", line 497, in hpai_body
body.extend(ip_to_array(self.control_socket.getsockname()[0]))
AttributeError: 'NoneType' object has no attribute 'getsockname'
16-10-29 11:13:07 root: Disconnecting KNX/IP tunnel...
16-10-29 11:13:07 homeassistant.core: Error inside async loop: Task exception was never retrieved
16-10-29 11:13:07 homeassistant.core: Exception inside async loop:
result = next(coro)
self.update()
self.disconnect()
16-10-29 11:13:22 homeassistant.components.api: STREAM 1991089944 WRITING data: ping
16-10-29 11:13:32 root: Disconnecting KNX/IP tunnel...
16-10-29 11:13:32 homeassistant.core: Error inside async loop: Task exception was never retrieved
16-10-29 11:13:32 homeassistant.core: Exception inside async loop:
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 208, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
self.disconnect()
self.disconnect()
pi@raspberrypi:~/.homeassistant $
Each time I start with a clean reboot between config changes:
Any help?
