Since version 0.115 entities of knx are now inside the integration domain.
I have more than 700 lines of knx definition (more than 150 entities) and it was organised by purpose (lightning, blinds, heat or fan control …).
Is there a way to define them without grouping them by entity type ?
For example I would like to define the sensor, light, switch of a KNX object together, instead of spiting in the sensor list, light list and switch list.
This was required by HA https://github.com/home-assistant/architecture/blob/3a280053dbd12c80776ba271155a95c9ebb666b2/adr/0007-integration-config-yaml-structure.md
How did you organize different entity types before this change?
Before 0.115 I was able to do multiple lists using numbers after the entity type:
#garage
switch 2:
- platform: knx
sensor 2:
binary sensor 2:
#heating
switch 3:
sensor 3:
binary sensor 3:
As a parallel, my KNX group is organisation is
- 0/X/X : lights
- 0/0/X : global
- 0/1/X : floor 1
- 0/2/X : floor 2
- 1/X/X : heating
- 1/0/X : global
- 1/1/X : floor 1
- 1/2/X : floor 2
- 2/X/X : blinds
… - 3/X/X : sockets
each section has multiple types.
It would be great if we could create sections in the knx integration configuration:
knx:
section "lights":
binary_sensor:
switch:
light:
section "heating":
binary_sensor:
switch:
climate:
I would also be happy to have separate yaml files with “include” for the different sections (but not per entity type)
Thanks for the thread. I downgraded to 0.114 yesterday after having no clue why my complicated KNX integration, which worked flawlessly sincs 0.47, stopped working.
I don’t have time to rewrite the whole configuration, let alone read me into how do do it and will be sticking to 0.114 then
essentially you’ll have to
- find your knx entities,
- cut&past them under the
knx:
key, - ident them with 2 more spaces and
- remove
platform: knx
so
knx:
switch:
# this is top level - here could have been knx and non-knx switches
- platform: knx
address: "6/5/4"
will become
knx:
switch:
# here are only (and every) knx switches
- name: "Switch"
address: "6/5/4"
@farmio I changed this:
knx:
tunneling:
host: '192.168.1.154'
port: 3671
local_ip: '192.168.1.140'
light:
- platform: knx
address: '1/1/9'
state_address: '1/3/9'
to this:
knx:
tunneling:
port: 3671
light:
- name: 'Entrada focos'
address: '1/1/9'
But it still doesn’t work.
What do you mean by “remove platform: knx” ?
UPDATE:
Solved!! In my ~100 KNX entites, I had a cover with a position_state_address: ‘’ (blank)
That never caused a problem, until now.
So, I assigned the correct KNX address, and my KNX integration is now fully functional again.
