My config file report an error
- Invalid config for [cover.knx]: [stop_address] is an invalid option for [cover.knx]. Check: cover.knx->stop_address. (See ?, line ?).
The stop_address variable is not known but exists in the documentation
But … I never succeed to have a valide configuration when I put knx device inside knx block. That’s why I put elements inside cover: while indicating platform knx
It is very strange as I followed documentation and your example
Error: Testing configuration at /config
Failed config
knx:
- Invalid config for [knx]: [cover] is an invalid option for [knx]. Check: knx->knx->cover. (See /config/configuration.yaml, line 24).
You’re welcome I did not think of the version first as well, however I then checked the source code and saw that some additions have only been done very recently.
