pmarco094
(Marco )
September 30, 2021, 6:33am
1
Hi all,
i have a problem with my KNX integration.
There are two identical switches in the Bus. They are not physical, but controlling the movement sensor.
One of them is working fine, just as expected. But the other one turns exactly after 1 hour to state “on” if it is “off”.
There is no automation in HA, no automation in the KNX Bus. I checked the logs on the KNX and the “on” state update is send by HA to the Bus.
What could be the trick?
thanks, marco
Dujith
(Charles Evers)
September 30, 2021, 8:03am
2
What do you mean by identical? The same model/same knx group/same adress(i hope not).
How is the group setup in your configuration.yaml?
Gonna need alot more info to help
pmarco094
(Marco )
September 30, 2021, 8:53am
3
I mean identical configuration, and same model.
Here is my configuration:
- name: Diele Bewegungsmelder sperren
address: "1/0/1"
state_address: "1/0/1"
- name: Garage Bewegungsmelder sperren NEU
address: "1/0/5"
state_address: "1/0/5"
“Diele” ist working fine. “Garage” is the entity with the problem.
Dujith
(Charles Evers)
September 30, 2021, 8:59am
4
What does the history say for the entity within HA? Does it also show an on?
farmio
(Matthias Alphart)
September 30, 2021, 9:16am
5
Every hour (exactly 1 hour after last telegram) by default the knx Integration reads the status of a state_address.
So it should send a GroupValueRead request to 1/0/5 (and 1/0/1). That’s the same as if you pressed “Read” Button (“Lesen”) in ETS Diagnose GroupMonitor. Try that from ETS for both addresses and post the results please.
pmarco094
(Marco )
September 30, 2021, 9:37am
6
Yes, in the History it shows “turned on”
pmarco094
(Marco )
September 30, 2021, 9:39am
7
At the moment i have no access to the ETS but i have the output from the HA Log when Read is starting.
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 1/0/5 for Garage Bewegungsmelder sperren NEU - State
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="0.0.0" destination_address="1/0/5" payload="<GroupValueRead />" />
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.knx] Sending: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="21" />
body="<TunnellingRequest communication_channel_id="16" sequence_counter="156" cemi="<CEMIFrame SourceAddress="IndividualAddress("1.1.200")" DestinationAddress="GroupAddress("1/0/5")" Flags="1011110011100000" payload="<GroupValueRead />" />" />" />
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.knx] Received: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" Reserve="0" TotalLength="10" />
body="<TunnellingAck communication_channel_id="16" sequence_counter="156" status_code="ErrorCode.E_NO_ERROR" />" />
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.knx] Received: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="21" />
body="<TunnellingRequest communication_channel_id="16" sequence_counter="90" cemi="<CEMIFrame SourceAddress="IndividualAddress("1.1.200")" DestinationAddress="GroupAddress("1/0/5")" Flags="1011110011100000" payload="<GroupValueRead />" />" />" />
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.knx] Sending: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" Reserve="0" TotalLength="10" />
body="<TunnellingAck communication_channel_id="16" sequence_counter="90" status_code="ErrorCode.E_NO_ERROR" />" />
body="<TunnellingRequest communication_channel_id="16" sequence_counter="91" cemi="<CEMIFrame SourceAddress="IndividualAddress("1.1.11")" DestinationAddress="GroupAddress("1/0/5")" Flags="1011110011100000" payload="<GroupValueResponse value="<DPTBinary value="1" />" />" />" />" />
body="<TunnellingAck communication_channel_id="16" sequence_counter="91" status_code="ErrorCode.E_NO_ERROR" />" />
2021-09-03 08:56:31 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.1.11" destination_address="1/0/5" payload="<GroupValueResponse value="<DPTBinary value="1" />" />" />
farmio
(Matthias Alphart)
September 30, 2021, 10:50am
8
Well, there is your answer (only xknx.telegram logs are of interest here).
Device 1.1.11 responds with 1
(True
or ON) so all Devices on the Bus (with active U-Flag (“Aktualisieren”) including HA) will accept that.
This was not sent from HA - but requested. Does the other GA respond differently ?
pmarco094
(Marco )
September 30, 2021, 3:41pm
9
Ah ok now i understand.
I wondering where the “1” is coming from. The other Switch is exactly configured like the problem switch.
Here the log from the other switch. This one is answering with “0”
2021-09-30 17:36:25 DEBUG (MainThread) [xknx.knx] Sending: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="21" />
body="<TunnellingRequest communication_channel_id="16" sequence_counter="64" cemi="<CEMIFrame SourceAddress="IndividualAddress("1.1.200")" DestinationAddress="GroupAddress("1/0/1")" Flags="1011110011100000" payload="<GroupValueRead />" />" />" />
2021-09-30 17:36:25 DEBUG (MainThread) [xknx.knx] Received: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" Reserve="0" TotalLength="10" />
farmio
(Matthias Alphart)
September 30, 2021, 4:04pm
10
There is no answer in the log you posted.
Do you mean it is configured the same in ETS?
farmio
(Matthias Alphart)
September 30, 2021, 7:05pm
12
You will have to solve this from ETS. There is nothing you can do from HA when the device is reporting a wrong state (except not sending the read request but that’s not solving, but ignoring the problem).
pmarco094
(Marco )
October 1, 2021, 6:37am
13
ok thank you. I will check this next week on the ETS. I will post the solution then. Thank you.
Could you solve it?
I’m very interested in the answer, cause I have nearly the same Problem…
maybe something wrong with the GA?
Thx
