Knx HVAC group objects
Hi everyone
I am a beginner in this job, but I managed to create a working system in home assistant. But I got to the heating and got stuck here. I have a KNX system, and my actuator it is very unusual i think, i didn’t find any information for setting up this type of actuators. Maybe someone can help me to link this objects.
knx:
  climate:
    - name: "Kitchen"
      temperature_address: "5/1/1"    - i am thinking this is a temperature value from a thermometer
      setpoint_shift_address: "5/1/2"
      setpoint_shift_state_address: "5/1/3"
      target_temperature_state_address: "5/1/4"
      operation_mode_address: "5/1/5"
      operation_mode_state_address: "5/1/6"
And here is my actuator group objects
Hi :wave:!
It would help to see what GAs are connected to those objects - so one can check your existing config.
Also what manufacturer, model is the actuator?
temperature_address: “5/1/1” - i am thinking this is a temperature value from a thermometer
Yes.
The only GA connected is the temperature address, what should i connect to?
The Actuator it is Hager TXM646T
This is an actuator without integrated regulator (unlike the TXM646R for example).
The HA Knx climate entity is meant to communicate with a regulator, not a plain heating actuator.
A plain actuator manages conversion of % value to PWM signal.
A regulator calculates % value from current and target temperature over time.
ok and what should i do?
Get a regulator.
Some options:
  • maybe you already have one in your system (logic engine, wall switch, room thermostat etc)
  • buy a Knx regulator
  • use HA as regulator
Why is the current actuator not linked to anything? Is this a new building? Who did plan the setup / choose the actuator?
I have some KNX Multitouch Pro Merten pannel
It is a new building, proiect and i made it myself whit very small knowledge.
Well, if their application provides regulators use them.
Otherwise consider changing your actuators to one of
  • Gira 212900
  • MDT AKH-0600.03 (or the 4 or 8 fold variant)
Hi
Luckily the actuators were replaced. Now I have Gira 212900 model.
Could you please help me with the pairings?
Home assistant
temperature_address: “A”
setpoint_shift_address: “B”
setpoint_shift_state_address: “C”
target_temperature_state_address: “D”
operation_mode_address: “E”
operation_mode_state_address: “F”
Gira Actuator
|327|Controller 1 - input|Presence button|1 bit|switch “a”
|322|Controller 1 - input|Operating mode switch-over|1 byte|HVAC mode “b”
|326|Controller 1 - input|Operating mode forced-control|1 byte|HVAC mode “c”
|336|Controller 1- output|Current setpoint shifting|1 byte|counter pulses (-128…127) “d”
|337|Controller 1- input|Preset setpoint shifting|1 byte|counter pulses (-128…127) “e”
|357|Controller 1- output|Command value for heating|1 byte|percentage (0…100%) “f”
|320|Controller 1- input|Basic setpoint|2 bytes|temperature (°C) “g”
|334|Controller 1- output|Set temperature|2 bytes|temperature (°C) “h”
|381|Controller 1- output|Actual-temperature|2 bytes|temperature (°C) “i”
|382|Controller 1- input|Received temperature 1 (temperature sensor 1)|2 bytes|temperature (°C) “j”
Multitouch pro
|238|Temperature alarm (resultant)|1 bit|1-bit, switch |1|
|221|Frost/heat protection input|1 bit|1-bit, switch |2|
|222|Frost/heat protection output|1 bit|1-bit, switch |3|
|224|Status|1 bit|1-bit, switch |4|
|239|Floor temperature alarm|1 bit|1-bit, switch |5|
|219|Operation mode input|1 byte|DHW mode |6|
|240|Correcting variable heating (basic level)|1 byte|8-bit unsigned value, percentage (0…100%) |7|
|225|Status 1 byte|1 byte|8-bit unsigned value, counter pulses (0…255) |8|
|220|Operation mode output|1 byte|8-bit unsigned value, counter pulses (0…255) |9|
|227|Setpoint input|2 bytes|2-byte float value, temperature (°C) |10|
|229|Setpoint shift input|2 bytes|2-byte float value, temperature difference (K) |11|
|230|Setpoint shift output|2 bytes|temperature difference (K), 2-byte float value |12|
|233|Basic setpoint shift input|2 bytes|2-byte float value, temperature difference (K) |13|
|234|Basic setpoint shift output|2 bytes|2-byte float value, temperature difference (K) |14|
|235|External temperature 2 byte|2 bytes|2-byte float value, temperature (°C) |15|
|237|Actual temperature (resultant)|2 bytes|2-byte float value, temperature (°C) |16|
|226|Status 2 byte|2 bytes|2-byte unsigned value, pulses |17|
|228|Setpoint output|2 bytes|2-byte float value, temperature (°C) |18|
Oh dear… that actuator is a very versatile device - the configuration depends on how it is parametrized.
I’d recommend to read the HA knx climate entity documentation and try to get it to work with one channel. https://www.home-assistant.io/integrations/knx/#climate
Giras actuator manual provides a very detailed description for all its parameters and functions.
If you have specific questions, I’m happy to help.
