jos89h
(Josh)
1
I am trying to install the KNX integration https://www.home-assistant.io/integrations/knx/ but have issues.
When i press the add integration link it takes to my HA and asks if i want to install KNX. I select yes and a error message comes up
Error
Config flow could not be loaded
I also cant install manually as it does not show in the available integrations
farmio
(Matthias Alphart)
2
Hi !
What version of HA (core) are you using?
farmio
(Matthias Alphart)
4
UI config for Knx was added in 2021.12. I’d recommend updating to the most current version of HA.
jos89h
(Josh)
5
Thank you, updating now. I haven’t used HA in a while since I set up what I needed last year
