KNX integration - can acces 'Entities' tab
I am using the KNX integration. has been working well…
this moring i noticed an missing ‘entitiy’ in the dashboard…
I wanted to check this light in the KNX ‘Entities’ tab but i can not acces this anymore…
when i navgate to the KNX integration (left menu bar) then I have different tabs on the top but when i cant to go to ‘Entities’ (where I define everything/link the adresses) i now get the message:
Cannot read properties of undefined (reading 'attributes')
I tried looking in the ‘configuration’.yaml file… but i can not find anything about KNX…
in the strucutre i can not find anything about KNX, i was hoping to see there the entities i created trouhg the UI?
I also notice that my HACS is not working… (the integrations are still working, but when i go to ‘HACS’ i get this message: Unable to load the panel source: /hacsfiles/frontend/entrypoint.js?hacstag=20250128065759. I don’t know if it is related.
you can find it in the .storage folder (hidden folder)
Hi :wave:!
The HACS thing doesn’t seem to be related. KNX entities tab issue is explained here: Disabled HA Entities prevent listing of KNX entities · Issue #230 · XKNX/knx-frontend · GitHub
TLDR you have disabled a Knx entity.
thanks for this.
i was able to fix everything (and the HACS thing was solved by clearing cache in the browser…)
