Knx light with only Percentage control
Did I miss something, or is it not possible to add a light without a address for on/off?
I use a DaliGateway that automatically controlls on/off for the power based on the requested brightness of the lamp. So I actually do not have any switching group for it on the knx side. Trying to configure this via yaml did not work (as i kinda expected, as the documentation said address is required).
Is there some other way to get these lights into homeassistant?
  - name: Lamp_example
    brightness_address: "0/1/205"
    brightness_state_address: "0/1/206"
Hi :wave:!
The schema doesn’t allow that.
As a workaround for such a light, you could try to configure a template entity with knx.send and knx.telegram as trigger.
Anyway, most Dali gateways have very extensive configuration options. I’d be surprised if you couldn’t add a binary on/off object.
Thanks for the response.
I think I should be able to add one, I will test in a few days when I have access to the computer with the knx dongle again.
