KNX "Not Loading" after adding sensor?
I have a fully working KNX integration with switches and binary sensors. But after adding a “Sensor” (Lux sensor) the knx stops working on my ha?
afbeelding
I added this to the KNX section in my config file ;
  - name: "Lichtsterkte parking"
    state_adress: "0/1/3"
    type: illuminance
i followed the KNX integration steps;
I could use help on this! :slight_smile:
thx in advance!
Hi :wave:!
You are missing a “d” in “address”. And I guess the missing indentation is just a copy&paste issue - if not, you’d need to correct this too.
The yaml checker (in dev-tools) or the logs should tell you about the validation error.
You have got to be shttng me… for fuck sake i looked an looked at every line… thanks!
