My sensor values from temperature sensors need scaling. Need to multiply the values by 10 to get the correct reading. Any way to do this in the configuration? Uses DPT 9,001 temperature
I think you’ll need to use a template for this.
Or do it in KNX.
Thank you for the rapid reply, I am now testing with a template. This is my first template, so i had to struggle a bit for the syntax, but finaly I got it
it should be possible to solve in KNX as well. The sensors come from a ProfibusDP / EIB converter that can not handle larger numbers than 2047. But templates solved the problem for me.
Hi Borge, can you post that template you made by any chance?
