I am going to deploy a KNX system and I would like to use a knx server which allows easy integration and automation. I would like to deploy a knx server which provides a public and documented API accesible over tcp/ip. Doing some google search I found this brand that provides a restful api in their knx servers:
Hi @pescobar thank you for sharing your findings.
Have you or anyone reviewed the fact that HA does not support KNX Secure as per the note “Please note, the knx platform does not support KNX Secure.”, and what implications does that have?
Do we know if it’s planned or can it be done (if so it will probably happen someday) that HA will be able to handle KNX Secure?
I am looking at using JUNG.DE hardware which is KNX compatible, has anyone had any experience on having a central server and controlling it all with HA on top?
Best regards,
Enric
The implications are simply that you can’t use an interface with Knx Secure turned on. It should be possible to disable this feature, then the HA integration should work fine.
No one working on xknx owns Knx Secure Hardware so this is not tested.
To implement it would theoretically be possible, but afaik there are currently no plans to do so.
