KNX Update the Project file not Possible
Hi, trying to load a new Knx Project to the HA due to some changes in the KNX Project i always get an error: Upload fialed; “NetworkError when attempting to fetch resource.”
The old version works, but i have to upload the new file because i have some new Groupe Adresses which should be implemented.
Do i have to Delete the Projectdata first?
Would that mean i have to redo alle the KNX Kofiguration new?
Thank You very much
Daivd
Update: I have tried to delete the Project Data, but no Difference. I can not upload a new project file.
I will reload a backup file now.
No and no. Configuration isn’t touched by project data.
Have a look at the logs (HA and browser) if there are any more hints.
NetworkError is awkward - if it can’t be parsed, there are usually other errors shown. Maybe try from a different device on your local LAN. Are you using any reverse proxies or something like that in between your browser and HA instance?
No it worked; I just Don´t know why.
I looked at the HA log Files, but didi not find anything.
I tried the local HA Adress instead the Nabu Casa.
This worked now although it did not work before.
Anyway i can go on now. Thank You for Helping! :+1:
