Kodi integration - artwork during playback not showing
When a media is beeing played by Kodi, the title but also the artwork is presented.
Unfortunately, for me only the title is shown but no artwork.
In an attempt to figure out if the problem lies at KODI or Home Assistant. I used api cliënt Postman with the following request and received the artwork as a response.
The issue seems not to be at Kodi api side because when i use a api cliënt like Postman and run the following requests, I receive all the necessary artwork, which makes me to believe that Kodi integration is not sending the correct request or not interpreting the response correctly.
I also used Home assistant developer tools > action. Which gave me a parameter error, see further below.
I am not sure if i missed something or is this a bug within Kodi integration.
I bit of help would be much appreciated.
POSTMAN
Request:
http://192.168.1.22:8080/jsonrpc
Body:
  "jsonrpc": "2.0",
  "method": "Player.GetActivePlayers",
  "params": {},
  "id": 0
Response:
    "id": 1,
    "jsonrpc": "2.0",
    "result": {
        "item": {
            "art": {
                "banner": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmoviebanner%2finterstellar-542033b1b28dd.jpg/",
                "clearart": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fhdmovieclearart%2finterstellar-5463e7ad94049.png/",
                "clearlogo": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fhdmovielogo%2finterstellar-541dd6756e663.png/",
                "discart": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmoviedisc%2finterstellar-544fc7176aba4.png/",
                "fanart": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmoviebackground%2finterstellar-544bb9af46801.jpg/",
                "icon": "image://DefaultVideo.png/",
                "keyart": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmovieposter%2finterstellar-54246e41368d5.jpg/",
                "landscape": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmoviethumb%2finterstellar-541db498b25cf.jpg/",
                "poster": "image://https%3a%2f%2fassets.fanart.tv%2ffanart%2fmovies%2f157336%2fmovieposter%2finterstellar-550825f7cc108.jpg/",
                "thumb": "image://video@smb%3a%2f%2f192.168.1.22%2fD%20Content%2fVideo%2fMovies%2fInterstellar%20(2014)%2fInterstellar%20(2014)%20Remux-2160p%20Proper.mkv/"
            "id": 3824,
            "label": "Interstellar",
            "type": "movie"
HOME ASSISTANT> Developer tools > actions
service: kodi.call_method
  entity_id: media_player.10_79_80_127
  method: Player.GetItem
  playerid: 1
  properties:
    - art
In the log the following lines are shown:
2025-02-06 21:11:20.344 ERROR (MainThread) [homeassistant.components.kodi.media_player] Run API method media_player.192_168_1_22.Player.GetItem({'parameters': {'playerid': 1, 'properties': ['art']}}) error: {'code': -32602, 'data': {'method': 'Player.GetItem', 'stack': {'message': 'Missing parameter', 'name': 'playerid', 'type': 'integer'}}, 'message': 'Invalid params.'}
Found a way to fix it? I have the same problem for a long time, but hoped it will fix itself, but it did not happen…
No, i did not but in the meantime I steps away from Kodi for otther reason. So, this post is not relevant for me anymore.
